Hi all,
when I write the Neon Intrinsic code as below
int32x4_t q;
int16x4_t d;
some thing I loaded into d register
q = vshll_n_s16(q, 16)
when I tried to build the code, the compiler is throwing error as the supported shift range is 0-15 only....I'm using Code warrior & RVDS4.0 tools
but when write the code in Assembly it is working fine with out any issues VSHLL.S16 q0,d0,#16
why it is not working in Intrinsics, when it is working in Assembly???
when I referred the latest ARM doc it says like shift value 16 is suported
Arm Compiler version 5.04 armcc user guide - ARM DUI0472J - section 18.15 - page 958 - int32x4_t vshll_n_s16(int16x4_t a, __constrange(0,16) int b); // VSHLL.S16 q0,d0,#0
Thanks in advance.....
The Actual Error Message that I'm seeing is
Error : #2529 : expression must be an integral constant in range 0 to 15
