Do we have any official benchmark comparing ARM and GNU compilers?
Few of my customers started to have concerns on the quality of the GNU`s GCC compilers.
Before I talk about the performance gain in using the ARM compiler to my clients, I would like to know is there any
official compiler benchmark comparing the ARM compiler and GNU?
I am only hearing that usage of NEON instruction through ARM compilers yields better performance compared to
doing the same thing using GNU`s GCC compiler?
Is there any document comparing different aspects of both of these compilers?
Regards,
  • ARM doesn't publish benchmark comparisons between compilers. There are far too many variables (compilers, compiler versions, benchmarks, command line options, etc) to do this in a meaningful way. Instead, we encourage users to run their own tests and we are happy to provide evaluation licenses to enable this.
    Generally speaking, the ARM Compiler excels at ...
    • Compact code size
    • Library size and performance
    • NEON autovectorization performance
    • Performance / code size tradeoff, i.e. very good performance without compromising code size
    These are of course generalisations and we encourage users to run their own tests.
  • Thanks for your feedback. Much helpful.
