Cannot obtain license for compiler(feature compiler5) with license version 5.0201301?
1) I am using uvision 3.0 version to build my application and I am getting an image size X. Is it possible to reduce the size by using DS-5.
2)I have installed DS-5 evaluation version 5.14 and i created sample project.If I try to build my project I am getting error as
  Cannot obtain license for compiler(feature compiler5) with license version 5.0201301.
Please help me how to come out of this.
  • Hi,
    Newer versions of Keil MDK and DS-5 Development Studio both use the same ARM Compiler. Whether you get any code size reduction depends on the options you use at compile time. By default, it will optimize for space.
    Did you register for an eval license? If not, you can find this under Help > ARM License Manager
    Thanks,
    Joe
