// mpu test
#include "stm32.h"
#include "type.h"
extern u32 mpu_reg1_begin_;
extern u32 mpu_reg1_end_;
__attribute__ ((section (".mpu_r1")))
int reg1[256];
bool init_mpu();
// ref: http://blog.feabhas.com/2013/02/setting-up-the-cortex-m34-armv7-m-memory-protection-unit-mpu/
// mymain is extern "C" declare
void mymain()
init_mpu();
reg1[0] = 10;
//int a = reg1[0];
int i=5;
while(1)
i++;
#define MPU_TYPE_REG_ADDR 0xe000ed90
#define MPU_TYPE_REG (*((u32 volatile *)MPU_TYPE_REG_ADDR))
#define MPU_CTRL_REG_ADDR 0xe000ed94
#define MPU_CTRL_REG (*((u32 volatile *)MPU_CTRL_REG_ADDR))
#define MPU_NUM_REG_ADDR 0xe000ed98
#define MPU_NUM_REG (*((u32 volatile *)MPU_NUM_REG_ADDR))
#define MPU_BASE_REG_ADDR 0xe000ed9c
#define MPU_BASE_REG (*((u32 volatile *)MPU_BASE_REG_ADDR))
#define MPU_ATTR_SIZE_REG_ADDR 0xe000eda0
#define MPU_ATTR_SIZE_REG (*((u32 volatile *)MPU_ATTR_SIZE_REG_ADDR))
// ref: arm cortex-m3: 嵌入式系統設計入門 p13-9
bool init_mpu()
// ref: Cortex™-M3 Technical Reference Manual 9.2 (file name: DDI0337E_cortex_m3_r1p1_trm.pdf)
// in stm32f4discovery the value is 0x800
// so there are 8 regions
// qemu-system-arm -M lm3s6965evb -kernel list.bin -S -gdb tcp::1234
// the mpu_type is 0x0
#if 0
u32 volatile *mpu_type_reg_addr = (u32*)0xe000ed90;
if (*mpu_type_reg_addr == 0) // there is no mpu
return false;
#endif
if (MPU_TYPE_REG == 0) // there is no mpu
#if 1
// base 0x0, 4g size
MPU_NUM_REG = 0;
MPU_BASE_REG = 0;
MPU_ATTR_SIZE_REG = 0x307003f;
//(*((u32 volatile *)MPU_BASE_REG_ADDR)) = 0x307002f;
#else
MPU_NUM_REG = 1;
MPU_BASE_REG = (u32)&mpu_reg1_begin_;
MPU_ATTR_SIZE_REG = 0x707000F; // read only
//MPU_ATTR_SIZE_REG = 0x307000F; // r/w
// ap: 111 read only
// size: 256 byte
// S: 1, C: 1, B: 1
// TEX: 000
MPU_CTRL_REG = 1; // enable MPU
__asm__ ("isb");
__asm__ ("dsb");
return true;
My platform is stm32f4discovery.
language: c++/arm-none-eabi-g++ (32-bit ARM EABI Toolchain JBS-2013.05-23-v2013.05-1-gd66a29f) 4.7.3
I setup 2 regions, one for base 0x0, size 4g, another is reg1, size: 256 byte, read only,
I expect invoke MemManage exception isr, but always invoke hard-fault, when I write reg1[], (reg1[0] = 10;) why?
SYSTEM_HANDLER_CTRL_STATE_REG |= (1 << 16); // enable mem-fault exception
After adding the setting, mm_isr can be call.
