Hi
I am currently trying to run the tutorial from openvirtualization.org. The first step includes booting Linux in secure mode without using any of the Trustzone features. Already here I have the problem that the boot loader binary cannot be loaded by fast models.
I am used FastModels 8.3 with the example Cortex A9 project. When loading the elf file I receive the following error message:
Warning: Failed to write bytes at address range [0x80000000..0x80000287] when loading image "/home/dev/projects/fast_models/trustzone/otz_linux/boot/RTSM/normal.elf".
Warning: Failed to write bytes at address range [0x80008000..0x803B4E53] when loading image "/home/dev/projects/fast_models/trustzone/otz_linux/boot/RTSM/normal.elf".
The debugger takes a rather long time to load the binary and then the correct code is shown in the debug window but tin the memory window all is blank or filled with the same pattern over and over again. When I check the binary with objdump it looks correct.
Does someone have a clue what could be wrong?
The tutorial I followed can be found at http://www.openvirtualization.org/SierraVisor_SierraTEE_Android_Boot_Build_Guide.pdf
Hi mrks, I am moving this to Software Development Tools, where the Fast Models experts are more likely to see it. (http://community.arm.com/docs/DOC-7896#GroupGreyedOut)
hi, could you raise a esl support ticket please? Then our support guys can pick it up. This is a public forum, so no formal supports on paid products via this forum. The purpose of the forum is for general technical discussion, not for product support. Thanks.
Hi George,
I have raised ticket.
Thanks.
