ARM DS-5 Compiler issue: fatal error: No such file or directory
Dear all,
I'm tring programing with ARM DS-5 on Zedboard, I just made a simple project to test Bluetooth function.
In this project some bluetooth header files were needed, I copied the header files to "DS-5 install path/include/", but DS-5 compiler shows error.
**** Build of configuration Default for project Bluetooth_Scan1 ****
make all
arm-linux-gnueabihf-gcc -c -O1 -g -fno-omit-frame-pointer -marm -march=armv4t -mfloat-abi=soft bluetoothscan.c -o bluetoothscan.o
bluetoothscan.c:12:33: fatal error: bluetooth/bluetooth.h: No such file or directory
compilation terminated.
make: *** [bluetoothscan.o] Error 1
**** Build Finished ****
So I copied the source code file (bluetoothscan.c file) to Zedboard, with GCC compiler.
#gcc -o bluetoothscan bluetoothscan.c -lbluetooth
it seems ok and the program works fine.
Maybe I just miss something?
  • Hi williamtai,
    If i am not wrong it's your project dependencies, i hope so it will help you.
    To Add "Path, Symbol, Library path" etc to work
    • Project Properties(right click the desire project in project explorer) -> C/C++ General -> Paths and Symbols
    OR
    • Project Properties-> C/C++ Build -> Settings-> ARM C COMPILER-> Includes
    For more info:
    Adding "Path, Symbol, Library path"
    and I always prefer relative path
    e.g.
    "${workspace_loc:/PROJECTNAME/FOLDER/Include}"
  • Hi asi,
    Thanks for reply.
    As the screenshot (be attached file in original post), library path had been setup in
    you can check it in Project Explorer on the left side.
    Most of library works fine, only bluetooth library can not be searched.
  • Hi,
    Sorry i didn't notice the "arm-linux-gnueabihf-gcc"
    Each include path is set in MAKEFILE of your project.
    e.g.
    CC_INCLUDE = \
        -I$(Project_Name) \
        -I$(Project_Name)/libgames-support \
        -I$(SYSROOT)/usr/include/ \
        -I$(SYSROOT)/usr/include/glib-2.0 \
        -I$(SYSROOT)/usr/include/gtk-2.0 \
        -I$(SYSROOT)/usr/include/cairo \
        -I$(SYSROOT)/usr/include/pango-1.0 \
        -I$(SYSROOT)/usr/include/atk-1.0 \
        -I$(SYSROOT)/usr/include/gdk-pixbuf-2.0
    thanks
  • Hi,
    I changed Makefile, add -I option, copied the bluetooth library to 'C:\bluetooth' for test.
    INCLUDE = \
         -IC:\bluetooth \
    make all
    arm-linux-gnueabihf-gcc -c -O1 -g -fno-omit-frame-pointer -marm -march=armv4t -mfloat-abi=soft -IC:\bluetooth  bluetoothscan.c -o bluetoothscan.o
    bluetoothscan.c:19:33: fatal error: bluetooth/bluetooth.h: No such file or directory
  • I just changed the path of bluetooth library, deleted the "arm-linux-gnueabihf-gcc" option '-IC:\bluetooth'.
    #include <C:\bluetooth\bluetooth.h>
    #include <C:\bluetooth\hci.h>
    #include <C:\bluetooth\hci_lib.h>
    and compiler works!
  • Because the #include looks like <bluetooth/bluetooth.h> you need to give -I the parent directory of 'bluetooth' (e.g. -IC:\ or -I.../From_Zedboard)
    [Also, using #include "bluetooth/bluetooth.h" would be technically better that #include <bluetooth/bluetooth.h> since the file is not from the C Standard.  But I realise that it's not your file to change.]
  • Thanks for reply, it really helps me.
    I changed Makefile, add option "-IC:\" since the bluetooth library (for test) in "C:\bluetooth", it works!
    I changed the option to "-I.../From_Zedboard" and it doesn't work.
    Makefile is located in project folder "C:\DS-5 Workspace\Bluetooth_Scan1".
    "-I.../From_Zedboard" means which path?
    I really confused about this.
  • "-I.../From_Zedboard" means which path?
    In your original .png you show that you have a folder "C:/Program Files/DS-5/includes/From_Zedboard"; I was just abbreviating the path as ..., you'll have to spell it out; sorry to cause confusion.
    [Please mark the question answered if it is.]
