We are augmenting the ARM architecture with a distributed data flow engine for high performance embedded intelligence applications. Is anybody familiar with the integration points of the ARM compiler stack and executable formats? I am looking for guidance which software environments to target? We are looking at Linux, Linaro and Android.
Welcome stillwater,
Would you have a bit more details about what you do?
Hi mattdupuy, would you be able to comment on the Android aspect?
Also, I am wondering if Guilherme could help on the DS-5 development tool point of view!
In Android space, Dalvik executables (DEX) are generated in the Android SDK from a combination of .class files converted in to Dalvik byte code and gcc/gas generated libraries from the NDK. If you're looking to integrate for Android, the Native Development Kit is managed by Google. The current version, r9, uses gcc v4.6 up to v4.8. What integration points do you need to patch in gcc/gas?
stillwater - The ARM Compiler is really not targeted at Linux. For Linux-based software stacks I suggest you look at Linaro GCC.
I am closing this question as there was no activity after the initial replies.
