Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
difference between saved copy and banked copy
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Rui Ma
over 12 years ago
Note: This was originally posted on 15th January 2013 at
http://forums.arm.com
Hi there,
I am reading ARM architecture manual v7, part B.
In the discretion of system register banks on page 1144, it refers SPs with a term as "banked copy"; while for the SPSRs, it uses "saved copy".
Is there a difference? I mean on the implementation of the micro-architecture.
Thanks in advance!
Martin Weidmann
over 12 years ago
Note: This was originally posted on 16th January 2013 at
In this case you confusing the name and the description...
ARMv7-A/R processors have several "modes", these include User mode, IRQ mode, Abort mode, etc...
Some processors registers are common. This means that whichever processor mode you are in, you will see the same copy of that register. Examples of common registers are r0 and r1.
Other register are "banked" this means that are multiple physical copies of that register, and which copy you see depends on the mode you're currently in. So when in Abort mode, you see the Abort mode copy of r13. Typically banked registers are sp (r13), lr (r14) and spsr.
Now SPSR stands for Save Program Status Register. As it happens, the SPSR is a banked register.
For completeness, the SPSR is used in exception handling. When you take an exception you change from your current mode to the mode associated with that exception. For example, an interrupt could take you from User mode into IRQ mode. There is a register called the CPSR (current program status register) which stores various bits of configuration, such as what mode you are in. When you taken an exception, the CPSR is automatically copied into the SPSR. Hence "saved".
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
