Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
XN bit support on ARMv7 Cortex A15
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
taani E
over 12 years ago
taani E
over 12 years ago
Note: This was originally posted on 10th January 2013 at
http://forums.arm.com
To verify the XN bit support on Cortex A15. I executed the attached c test code.
I followed below steps to test XN bit support.
1. I compiled attached test program i.e exectest with "-z execstack"option (gcc -z execstack -o exectest exectest.c -lpthread)
2. I
removed
XN bit related code in ./arch/arm/mm/mmu.c and burned kernel on target.
Filename : arch/arm/mm/mmu.c
Line: 346
if(cpu_is_xsc3() || (cpu_arch >= CPU_ARCH_ARMv6 && (cr & CR_XP))){
if (!cpu_is_xsc3()) {
#if 0
/* Mark device regions on ARMv6+ asexecute-never
* to prevent speculativeinstruction fetches. */
mem_types[MT_DEVICE].prot_sect |= PMD_SECT_XN;
mem_types[MT_DEVICE_NONSHARED].prot_sect |= PMD_SECT_XN;
mem_types[MT_DEVICE_CACHED].prot_sect |= PMD_SECT_XN;
mem_types[MT_DEVICE_WC].prot_sect |= PMD_SECT_XN;
#endif
if (cpu_arch >= CPU_ARCH_ARMv7 && (cr & CR_TRE)) {
3. Executed test program on target.
4.
I found some times successful execution with correct output and sometimes page fault.
As per my understanding this test program should always execute correctly and give correct output.
If I skip step 2 (means not commenting the XN bit related code) then also I have got the same behavior.
Please let me know how to verify XN bit support.
Thanks & Regards,
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 12 years ago
Note: This was originally posted on 9th January 2013 at
I think the v6 and v7 page tables are (mostly) the same unless you are using the large physical address space, so yes the v6 XN should work fine for Cortex-A15.
HTH,
Iso
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 12 years ago
Note: This was originally posted on 11th June 2013 at
Realize this is an old post, but I hit it with a Google search, so I thought worth posting "probable cause".
I suspect your test case is incorrect. You mention you are pushing executable code onto the stack and sometimes getting a fault, and sometimes not.
ARMv7 does not include hardware memory coherency between I-cache and D-cache, so you are getting a cache coherency problem where you have written the code to the D cache, but the I cache is probably trying to execute the old data rather than your new code. What you are trying to do is invalid without manual cache operations to ensure I and D sides of the memory system see the same data values.
HTH,
Iso
Cancel
Vote up
0
Vote down
Cancel
