Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
LDREX fails after MMU is enabled on Beagleboard xM
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Robbie VanVossen
over 12 years ago
Note: This was originally posted on 30th October 2012 at
http://forums.arm.com
I am attempting to port a build of xen-arm to work for the Beagleboard xM. This board uses TI's DM3730 processor, which is built on a Cortex A8 r3p2. My issue is that once the MMU is enabled, LDREX (and presumably STREX) instructions fail. I get a data abort exception when the LDREX instruction executes.
I know that the processor supports the LDREX/STREX instructions. The exclusive instruction support bits, [23:20], of c0, Instruction Set Attributes Register 4 is the expected 0x0. I also tested using LDREX before enabling the MMU and it doesn't cause an exception.
Setup:
Text is loaded to 0x8030_8000
Page Table:
Written from 0x8030_4000 to 0x8030_7FFF.
I am performing a 1 to 1 mapping at 0x8000_0000 for 1024 MB. The section descriptor format I am using is 0x8001_15EE + current page, where current page is 0x10_0000 to 0x4000_0000.
These values should give the following configuration:
Uses Sections
Bufferable: 1
Cacheable: 1
Execute-Never: 0
Domain: 0xF = Domain 15
Access Permissions[1:0]: 0x01
Access Permissions X: 0
Shareable: 1
Not Global: 0
Non-Secure: 0
Translation Table Base Registers (0,1) c1,c0, {0,1}:
0x8000_400B
This gives the following configuration:
Not Outer Shareable: 0 (Not Implemented SBZP)
Cacheable: 1
Shareable: 1
Region Bits: 0x1 = Normal memory, Outer Write-Back Write-Allocate Cacheable
Coprocessor Access Control Register c1,c0,2:
0x000F_0000
Priveledged and User mode access to CP10 and CP11.
Primary Region Remap Register c10, c2, 0:
0xff0a81a8
NOS7-0: 0xFF (Should be write ignored)
Mapping of S = 1 attribute for Normal Memory: 1 = Region is shareable
Mapping of S = 0 attribute for Normal Memory: 0 = Region is not shareable
Mapping of S = 1 attribute for Device Memory: 1 = Region is shareable
Mapping of S = 0 attribute for Device Memory: 0 = Region is not shareable
Primary TEX mapping for memory attributes (TRn):
TR0: 0x00 = Strongly Ordered
TR1: 0x10 = Normal Memory
TR2: 0x10 = Normal Memory
TR3: 0x10 = Normal Memory
TR4: 0x01 = Device Memory
TR5: 0x10 = Normal Memory
TR6: 0x00 = Strongly Ordered
TR7: 0x10 = Normal Memory
Normal Memory Remap Register c10, c2, 1:
0x40e040e0
Outer Cacheable property mapping for memory attributes n (ORn):
OR0: 0x00 = Region is Non-cacheable
OR1: 0x00 = Region is Non-cacheable
OR2: 0x10 = Region is WriteThrough, Non-WriteAllocate
OR3: 0x11 = Region is Write-Back, Non-WriteAllocate
OR4: 0x00 = Region is Non-cacheable
OR5: 0x00 = Region is Non-cacheable
OR6: 0x00 = Region is Non-cacheable
OR7: 0x01 = Region is Write-Back, WriteAllocate
Inner Cacheable property mapping for memory attributes n (IRn):
IR0: 0x00 = Region is Non-cacheable
IR1: 0x00 = Region is Non-cacheable
IR2: 0x10 = Region is WriteThrough, Non-WriteAllocate
IR3: 0x11 = Region is Write-Back, Non-WriteAllocate
IR4: 0x00 = Region is Non-cacheable
IR5: 0x00 = Region is Non-cacheable
IR6: 0x00 = Region is Non-cacheable
IR7: 0x01 = Region is Write-Back, WriteAllocate
Control Register c1, c0, 0:
0x10c53c7d
MMU Enable: 1
Enable Strict Alignment: 0
Data Caching Enabled: 1
Enable Program Flow prediction: 1
Instruction Caching Enabled: 1
Exception Vector Location: 1 = High Exception Vectors (0xFFFF_0000-0xFFFF_001C)
E-bit setting: 0
Non-Maskable Fast Interrupt enable: 0
Tex remap functionality: 1 = TEX remap enabled
Access Flag Enable: 0
Thumb Exception Enable: 0
Is there something I am missing or am I configuring something incorrectly?
Thanks,Robert VanVossen
Robbie VanVossen
over 12 years ago
Note: This was originally posted on 31st October 2012 at
Thank You! I have now fixed my problem.
The page table entries and the ttbr can be marked as shareable, but the PRRR bits need to all be marked as not shareable.
NS1: 0
NS0: 0
DS1: 0
DS0: 0
It seems to have been a problem with regions.
Cancel
Vote up
0
Vote down
Cancel
Robbie VanVossen
over 12 years ago
NS1: 0
NS0: 0
DS1: 0
DS0: 0
Cancel
Vote up
0
Vote down
Cancel
