Hi guys,
Does anyone knows how I can try my bare-metal code generated by DS-5 Development Studio on a RPI 2 /3
I dont know which files I need to copy into the SD card of the RPI so I can test it. The bare-metal code is running on the DS-5 studio but I need to install and play with it on a RPI 2. Anyone that has done this before?
Thanks!
Hi Ab - as this post hasn't received any responses yet, I have moved it to the Software Tools forum where you are more likely to receive an answer. Many thanks,Georgia
Below are a couple of resources you can look at. I'm not aware of any published information on DS-5, but will take a look and see if an example can be provided.
https://archive.fosdem.org/2017/schedule/event/programming_rpi3/
https://github.com/gingold-adacore/rpi3-fosdem17
The easiest way is to copy your bare-metal code to the SD card with the same name as the Linux image and it will run.
Thanks,
Jason
Here are more details on how to run bare metal on the Raspberry Pi 3 using DS-5.
https://community.arm.com/tools/b/blog/posts/running-bare-metal-software-on-the-raspberry-pi-3-using-arm-ds-5
