Hi All,
I have a Fast Model FVP from Fast Models 11.26 Base Rev C FVP.
Does it support FEAT_SVE*?
I care mostly of FEAT_SVE{,2} probably without other extentions but if they are also supported - even greater.
Thanks,
Marek
Dug further... I enabled "cluster{0,1}.has_sve=1" to "FVP_Base_RevC-2xAEMvA for armv8.5-a emulated and seeing kernel detects the CPU feature SVE.
However when I want to see SVE2 (cluster{0,1}.sve.has_sve2=1) with armv9-a emulated my bl1 fails. So I guess the answer to my question should be yes, it supports SVE and probably SVE2 too but I have two old firmware to see that.
Would it be right?
