AXI read burst request and response
Say the Initiator did the read request with 16 beats. Does AXI standard require the response to come in the same response or it can come in 16 separate single transactions?
The question comes from the context of SoC architecture with say AXI4 Initiator is connected through the NOC to AXI-lite. Or another version is when the transaction turns to be a slit one between different Targets. Should the NOC combine all the responses to create the same burst size as Initiator requested or this is not mandatory?
Thanks,
Khach
  • WSTRB indicating a smaller number of active byte lanes than AWSIZE indicated is not an error as previously explained. AWSIZE and AWLEN together tell you the maximum number of bytes that this transaction can transfer, and then WSTRB tells you which byte lanes in each AWSIZE width data transfer contain valid data.
    WLAST or RLAST being asserted for a transfer that isn't the final AWLEN or ARLEN indicated transfer IS a protocol violation. If you see this, the resulting system behaviour is undefined, and the source of the violation must be fixed. AxLEN and xLAST assertion must agree; neither has precedence.
    You should detect this (and all other protocol violation) during system verification simulations using protocol checker tools so that silicon components do not need to include protocol checking logic that will unnecessarily increase gate count.
  • Colin, thanks for the explanation. The part I am not clear and trying to get an explanation is slightly different.
    There are duplicates as it was indicated earlier: AWLEN/WSTRB, AWLEN/WLAST and some other. In case of the mismatch between AWLEN/WLAST this is a protocol violation. In case of AWLEN/WSTRB mismatch, for some reason this is not a protocol violation. What are the rationals behind this?
    What if AWLEN says only 2 bytes are valid on each transfer, but WSTRB does not mask any, so all of them end up being enabled. The factual transfer ends up being larger than what was initially booked to be allocated. There must be a reason this is not considered a protocol violation and this is where I need your help.
    Thank you.
  • The only "duplicate" information signals are the AxLEN and xLAST signals. Both tell you when the final transfer in the transaction will be. As Chris explained, for write transfers this gives the subordinate designer the choice of whether to count AWLEN number of transfers, or just accept transfers until WLAST is asserted.
    As I tried to explain, the ONLY signals that define how much data a write transaction can contain are AWLEN and AWSIZE. Together they tell you the length and width of the transaction boundaries. This is the MAXIMUM amount of data that could be transferred.
    WSTRB is a secondary signal that then tells you which of the byte lanes in each write transfer contain valid data. So in the AWLEN x AWSIZE bounded transaction, some of the data bytes might be tagged valid (WSTRB=1), some might be invalid (WSTRB=0), but those bytes whether valid or invalid will be what are passed on the bus in each data transfer, making up one of the AWLEN number of data transfers.
    So WSTRB is irrelevant when considering when a data transaction is ending. That is only on the (AWLEN+1) data transfer, when WLAST is asserted.
    Looking at extremes, you could have a write transaction with AWLEN indicating 8 transfers, with AWSIZE indicating 4 bytes per transfer, so a total maximum of 32 bytes possible, but WSTRB=4'b0000 for every one of the 8 transfers. So no valid data has been transferred, but there were 8 W channel transfers, and WLAST was asserted for that 8th data transfer. All perfectly legal from an AXI perspective, so no protocol violation or error.
    Yes, that last example is pointless, but I am just trying to show that WSTRB is not relevant when it comes to determining when a write transaction ends. It is only AWLEN and WLAST that will indicate when a write transaction ends.
    In the last question in your post you state AWLEN says only 2 bytes are valid on each transfer. I guess you meant AWSIZE as this indicates the maximum number of valid bytes per transfer. I think your misunderstanding here is that if you had a 32-bit (4 byte) data bus, and AWSIZE indicates 16-bit (2 byte) transfer widths, the protocol states that you can only assert WSTRB bits within the AWSIZE/AWADDR/AWBURST defined byte lanes.
    So if you had an incrementing burst signaled on AWBURST, AWSIZE was 2 bytes, AWADDR indicated a starting address of 0x2, and AWLEN indicated 4 transfers, all on a 32-bit data bus, the possible maximum valid byte lanes indicated on WSTRB could only be 4'b1100, 4'b0011, 4'b1100 and 4'b0011 for the sequence of writes (first transfer to the upper half of the 32-bit bus, the second to the lower half, and alternating for the duration of the transaction).
    As you can then see, the maximum number of WSTRB bits that could have been asserted in the transaction's 4 transfers is 8, which matches the AWLEN x AWSIZE (4x2) value. You cannot ever have the "factual transfer being larger that what was initially booked to be allocated".
  • Thanks for the detailed response. Yes, this is indeed where my confusion is. Looking at your example:
    Now, say, the WSTRB came as 4'b1111, 4'b1111, 4'b1111 and 4'b1111. This is a non-sense, but let's keep this extreme for the sake of understanding. Is not this more that was initially booked to be allocated?
    Or you are saying the originator must do it as 4'b1100, 4'b0011, 4'b1100 and 4'b0011 and never the way I shown above?
  • Referring to my answer above:
    For a write, AWADDR, AWLEN and AWSIZE define the maximum number of bytes that could be written.  WSTRB defines the bytes that are actually valid to write.
    If WSTRB indicates bytes as being valid which are defined as not valid by the above signals, then this is a hardware protocol violation.
    As described in A4.2.1 of the AXI.K Spec:
    "• Outside of the transaction container all write strobes must be LOW."
    So using the example above, WSTRB can never be 4'b1111 for any transfers.
    4'b1100, 4'b0011, 4'b1100 and 4'b0011 indicates the maximum number of bytes that can be valid for these AW attributes.  Any of the WSTRB bits that are 1 can also be 0 if the manager does not wish to write these bytes.
  • Thanks for all the responses. This was very helpful!
