LSTM support with Ethos-U NPU
Hello there,
I was recently developing and model which is required to use some LSTM layers. I found that in deed Ethos-U65 is supporting LSTM: https://developer.arm.com/documentation/102023/0000/Programmers-model/Operators-and-performance/Supported-data-types-and-operators.
I stumble upon a fact that with most of the frameworks it is hard to quantize those layers as their performance is poor (after PTQ). Can you suggest what is the right path for LSTM layer integration with NPU? Maybe use of dynamic quantization?
Thank you,
Tymo
