Failed to match cmsis-nn convolution function outputs with hand calculation for IN-channels greater than 1
Hello guys, I am new to ML/AI as a start I am trying to run a convolution layer on M4 by using CMSIS-NN function calls and comparing the output results with a hand calculated outputs for the same inputs and kernel.
I am using a arm_convolve_HWC_q7_basic cmsis-nn function for my convolution layer test and I am successfully able to infer the convolution layer with one channel i.e with cmsis-nn function call and the outputs are exactly matching with my hand calculation outputs.
But the tough part is when i am trying to run the same test with increase in INPUT-channels (greater than one) the outputs of the arm_convolve_HWC_q7_basic function outputs are not matching with my hand calculated outputs.
Please refer to my attached example reference and my code below and help me out with the missing solution thanks in advance.
FYI... I took the same inputs, kernels as shown in the example reference just to make life easy i.e to compare outputs easily.
0
