In a project which is focussed on accelerating the performance on ARM, I am using the mm_shuffle_epi8 implementation from the below page https://github.com/f4exb/cm256cc/blob/master/sse2neon.h#L981.
But above implementation is sub optimal and leading to performance costs.
Is there a right equivalent for _mm_shuffle_epi8 for ARM ?
There isn't an exact equivalent, but vtbl is likely a useful command for doing _mm_shuffle_epi8 in Neon.
As there isn't a direct equivalent, a completely generic version won't be as efficient, but if you have particular shuffles you'll get to something better.
I always plug the searchable list of Neon commands, and this guide will also be useful.
