Dear all,
I was trying to convert a tflite model to an ARM NN model. In tensorflow lite implementation, there is a mechanism called fusedActivation, which infuse the relu activation function with a FC layer. However, I didn't see any parameter in Fully-connected Layer Functions that can set up infusing in the ARM NN library. Does ARM-NN support this mechanism natively?
Many thanks!
Issue solved. Thanks for all.
That's great to know! Would you be able to share your solution here in case anyone else has the same issue?
