I am a data analyst trying to improve my knowledge of machine learning.
I've completed a model for a time-series dataset, where each point is 1 day apart, with no gaps. The specific model type that I have attempted is a multi-layered auto-regression testing tool bi-directional LSTM using tensorflow's keras, see model-specific code below:
model = keras.Sequential() model.add(Bidirectional(LSTM( units = 128, input_shape = (X_train.shape[1], X_train.shape[2]), return_sequences=True))) model.add(Bidirectional(LSTM( units = 64, input_shape = (X_train.shape[1], X_train.shape[2]), return_sequences=True))) model.add(Bidirectional(LSTM( units = 32, input_shape = (X_train.shape[1], X_train.shape[2]), return_sequences=True))) model.add(Bidirectional(LSTM( units = 16, input_shape = (X_train.shape[1], X_train.shape[2]), return_sequences=False))) model.add(keras.layers.Dense(16)) model.add(keras.layers.Dropout(rate = 0.5)) model.add(keras.layers.Dense(1)) model.compile(loss='mean_squared_error', optimizer='Adam') history = model.fit( X_train, y_train, epochs = 100, batch_size = 128, validation_split = 0.2, shuffle = False ) print(model.summary())
I've been told that this is likely overkill for this specific learning task by a superior member of staff but wanted to add it for full transparency. See summary below:
Layer (type) Output Shape Param # ================================================================= bidirectional (Bidirectiona (None, 50, 256) 133120 l) bidirectional_1 (Bidirectio (None, 50, 128) 164352 nal) bidirectional_2 (Bidirectio (None, 50, 64) 41216 nal) bidirectional_3 (Bidirectio (None, 32) 10368 nal) dense (Dense) (None, 16) 528 dropout (Dropout) (None, 16) 0 dense_1 (Dense) (None, 1) 17 ================================================================= Total params: 349,601 Trainable params: 349,601 Non-trainable params: 0 _________________________________________________________________
The model reports the loss values (after 100 epochs, using Mean Squared Error):
loss: 0.0040 - val_loss: 0.0050 (Overfit)
With an RMSE derived with: math.sqrt(mean_squared_error(y_train,train_predict)) and math.sqrt(mean_squared_error(y_test,test_predict)) with sklearn.metrics and the built-in function mean_squared_error from the aforementioned package.
sklearn.metrics
mean_squared_error
Train RMSE: 28.795422522129595
Test RMSE: 34.17014386085355
And for a graphical representation:
To which I finally arrive at my question; how do I better fit my model to more closely representing the noise within the data, as this is what I believe to be causing the high RMSE values. I have looked into attention mechanisms, in the hopes that I might be able to highlight specific peaks and troughs within the data, but it seems that these are best used with image/text prediction oriented models. I could try training over more epochs, but the model is already slightly overfitting, so this would exasperate this particular issue further.
I understand this is a fairly open-ended question but I have best tried to "show my working" and thank you in advance.
Hi!
The task sounds like function extrapolation.
Could you describe what inputs/outputs are used in the model? Is it some sort of floating window?
