Hi Experts,
I am trying to cross compile the existing Tensor Flow Lite code for microcontrollers into Cortex-M platform with arm-none-eabi-g++ compiler.
When I try to cross compile it for Cortex-M with either arm-none-eabi-g++ or arm-none-eabi-cpp it was showing linking error for _exit and more errors.
Please specify some mechanism for baremetal compilation.
As a valid question, you have to provide all the information completely. If it is not a valid question, others may ignore it directly or have no interest to answer it.
For your case, its' better to provide
- the detailed link error
- your Cortex-M environment e.g. what is the CPU type, what is your IDE
- g++ compiler version
- your compiler / linker options and commands
- anything else that can help the problem solvers to understand your questions so that they can analyze
