What are the real benefits of implementing IDAU from the viewpoint of chip designers?
We know that chip designers can use an Implementation Defined Attribution Unit (IDAU) to define a fixed memory map. A region can be defined as Secure,
Non-secure, or Exempt.
If SAU_CTRL ENABLE bit is set as 0, and the ALLNS bit is set as 1, then all memory regions comply with their IDAU settings.
However, if SAU_CTRL ENABLE bit is set as 1, from user's viewpoint all memory regions becomes Secure. Of course, the IDAU Non-secure regions also become Secure. Application developers can employ SAU to set some IDAU non-secure regions back to non-secure. All IDAU Secure regions cannot be set to Non-secure by SAU.
For embedded application developers, if the fixed IDAU memory map satisfies, the only thing need to do is setting SAU_CTRL ENABLE bit to 0, and the ALLNS bit to 1, to enable the IDAU memory security attributes.
Since the IDAU secure regions cannot be changed to non-secure, if the IDAU memory map does not satisfy, it implies more memory regions have to be set as Secure. The developer can set SAU_CTRL ENABLE = 1, so all memory regions become Secure, then use SAU to set some IDAU Non-secure regions back to Non-secure. As an example, assume we have 4 regions, their IDAU setting, SAU control register setting, SAU setting and final security attributes are listed below.
A B C D E
SAU_CTRL ENABLE=0 SAU_CTRL ENABLE=1
Region # IDAU ALLNS=1 ALLNS=0 ALLNS no impact SAU setting IDAU+SAU
1 Secure Secure Secure Secure Non-secure Secure
2 Non-secure Non-secure Secure Secure Non-secure Non-secure
3 Secure Secure Secure Secure Non-secure Secure
4 Non-secure Non-secure Secure Secure Non-secure Non-secure
My argument is that IDAU adds a lot of limitations to memory map but does not bring many benefits. For example, IDAU secure regions are always secure (cannot be change by SAU as non-secure). IDAU non-secure regions are changed to Secure as soon as SAU_CTRL ENABLE = 1. The few scenario that IDAU makes sense is the default IDAU memory map setting is good enough to application developers, in which case, developer only need set SAU_CTRL ENABLE bit to 0 and the ALLNS bit to 1 to activate IDAU without setting regions one by one.
Considering the many limitations and few benefits, what are the real benefits of implementing IDAU? I admit I have limited understanding to IDAU design. Thanks.
  • >IDAU non-secure regions are changed to Secure as soon as SAU_CTRL ENABLE = 1.
    I guess you have a typo. IDAU Non-secure regions are changed to Secure if SAU_CTRL.ENABLE=0 (default setting after reset).
    Several reasons for having IDAU:
    1 )SAU is limited to 8 regions in current Cortex-M23/M33/M35P implementations. If more regions are needed, IDAU can help. Please note you can define a large Non-secure region using the SAU, and then inside this memory space, use IDAU to make some of the sub-regions Secure and some of the sub-regions Non-secure. (You can also use Memory Protection Controller for parititoning of a memory block.)
    2) SAU is programmable. But for a SoC with fixed memory map, IDAU hardware can provide a lower gate count solution (lower power)..
    3) It is possible to have implement a programmable IDAU configuration register bank which help manage memory partition in multiple bus masters. SAU on the other hand, is for local processor only.
    regards,
    Joseph
