What sort of visibility does a non-secure debugger have of the secure sections?
This question was raised in the 'How to implement a secure IoT system on ARMv8-M' webinar, view all the questions in the round up blog post.
  • An ARMv8-M Processing Element such as Cortex-M33 or Cortex-M23 that implements the ARMv8-M Security Extension may or may not have Secure Debug enabled or disabled. There is a configuration option for the microcontroller vendor that determines whether a debugger is allowed to perform secure and non-secure accesses or only non-secure accesses. If the MCU is configured to only support non-secure debug, it will not have access to the secure memory and registers. Similarly there is a configuration option for the microcontroller vendor that determines whether a debugger is permitted to perform secure and non-secure trace, for example, ETM trace, or only non-secure trace. If the MCU only includes non-secure trace, then again, the debugger will only be able to capture trace when it is executing non-secure code.
