Summary-------Versatile Express V2M-P1 + CoreTile Express A15x2 A7x3 (TC2, HBI-0249A).MCC POST passes, DCC configuration completes, resets are released - but theBoot Monitor banner never appears on any UART.
The config card is byte-identical to the ARM DVD 5.2 "boards/Recovery" set, andthe MCC's own log confirms the Boot Monitor image was programmed.
Hardware / firmware-------------------- V2M-P1, HBI0190D, Rev D Variant A, S/N 0209480101-0094- CoreTile V2P-CA15_A7, HBI-0249A (Cortex-A15 r2p1 x2, Cortex-A7 r0p1 x3)- MCC v3.1.2 (Boot loader v1.1.2), IOFPGA build 16 (io_b116.bit)- Boot Monitor v5.2.1 (bm_v521r.axf)- 2 GB microSD FAT16, files from DVD 5.2 boards/Recovery, AUTORUN: TRUE
Symptom-------Last lines seen on UART0 (38400-8-N-1):
Releasing Daughterboard resets. Switching MCC log to UART1.
Per DDI0496 Example 3-1 the next line should be "ARM Versatile Express BootMonitor". Nothing appears on UART0, UART1, UART2 or UART3.
Verified correct----------------- NOR map: 0x0 bm_v521r, 0x40000 BOOTSCRIPT, 0x80000 SYSTEM.DAT, 0xC0000 ca15a7, 0x100000 kernel- Flash> read "bm_v521r" compared with the LOAD segment of bm_v521r.axf (195,984 bytes at file offset 0x34): identical- SYSTEM.DAT: magic 0xABCDEF01, four baud rates of 38400- MCC log: "Image: bm_v521r UPDATED from \SOFTWARE\bm_v521r.axf"- board.txt / images.txt / config.txt diff clean against the DVD
Tried, no effect----------------1. OSC8 = 40.0 (DDR2 320 MHz), the documented DDR2 erratum workaround for V2P-CA15_CA7 - confirmed applied in the DCC log2. SCC 0x700 as 0x0032F003 / 0x1032F003 / 0x0032E003 / 0x1032E0033. SCC 0xC00 with DBG_EN cleared (0x00000005) - the DCC no longer reports "Power down debug support enabled", but halting still fails4. SCC 0xC10 raised to 1000 mV - boot voltage stays at 900 mV (DVFS table only, as expected)5. BootMon patched to apply erratum 801819 (ACTLR[28:25] = 0b1111) - flashed and confirmed, no change6. BootMon patched to apply erratum 794724 (L2CTLR[9] = 1) - flashed and confirmed, no change7. SW[0] and SW[1] are OFF (default), S7-1 is OFF (NOR boot); the serial cable has no flow-control lines
ARM V2M Boot loader v1.1.2 HBI0190 build 2313 ARM V2M Firmware v3.1.2 Build Date: Apr 16 2013 Date: Thu 01 Jan 2004 Time: 12:54:57 Press Enter to stop auto boot... Daughterboard fitted to site 1. Switching on ATXPSU... ATX3V3: ON VIOset: 1.8V MBtemp: 30 degC Configuring motherboard (rev D, var A)... IOFPGA config: PASSED MUXFPGA config: PASSED OSC CLK config: PASSED Programming image \SOFTWARE\bm_v521r.axf Erasing Flash image bm_v521r . Erasing Flash . Writing Flash .Updating eeprom with image bm_v521r Image: bm_v521r UPDATED from \SOFTWARE\bm_v521r.axf Testing SMC devices (FPGA build 16)... SRAM 32MB test: PASSED VRAM 8MB test: PASSED LAN9118 test: PASSED USB & OTG test: PASSED KMI1/KMI2 test: PASSED MMC & SD test: PASSED DVI image test: PASSED AACI AC97 test: PASSED CF card test: PASSED UART port test: PASSED MAC addrs test: PASSED Reading Site 1 Board File \SITE1\HBI0249A\board.txt DB1 JTAG configuration complete. Setting DB1 OSCCLKS... DB1.0 DCC 0 SPI configuration complete. Writing SCC 0x40610007 with 0xFF00FF00 Writing SCC 0x40610046 with 0x01CD1011 Writing SCC 0x406101C0 with 0x0032F003 Writing SCC 0x40610100 with 0x33330C00 Writing SCC 0x40610048 with 0x022F1010 Writing SCC 0x40610049 with 0x0011710D Writing SCC 0x4061004A with 0x022F1010 Writing SCC 0x4061004B with 0x0011710D Writing SCC 0x4061004C with 0x022F1010 Writing SCC 0x4061004D with 0x0011710D Writing SCC 0x4061004E with 0x022F1010 Writing SCC 0x4061004F with 0x0011710D Writing SCC 0x40610300 with 0x00000007 Writing SCC 0x40610301 with 0x060E0356 Writing SCC 0x40610302 with 0x00000000 Writing SCC 0x40610303 with 0x00000000 Writing SCC 0x40610304 with 0x384061A8 Writing SCC 0x40610305 with 0x38407530 Writing SCC 0x40610306 with 0x384088B8 Writing SCC 0x40610307 with 0x38409C40 Writing SCC 0x40610308 with 0x3840AFC8 Writing SCC 0x40610309 with 0x3840C350 Writing SCC 0x4061030A with 0x3CF0D6D8 Writing SCC 0x4061030B with 0x41A0EA60 Writing SCC 0x4061030C with 0x3840445C Writing SCC 0x4061030D with 0x38404E20 Writing SCC 0x4061030E with 0x384061A8 Writing SCC 0x4061030F with 0x38407530 Writing SCC 0x40610310 with 0x384088B8 Writing SCC 0x40610311 with 0x38409C40 Writing SCC 0x40610312 with 0x3CF0AFC8 Writing SCC 0x40610313 with 0x41A0C350 DB1.0 DCC 0 SCC configuration complete. DB SMB clock enabled. Waiting for SITE1 CB_READY... Testing SMB clock... Configuring MUXFPGA for MB. Setting DVI mode for VGA. Releasing Daughterboard resets. Switching MCC log to UART1.
JTAG (low confidence)---------------------CMSIS-DAP probe at 500 kHz: DAP IDCODE 0x4BA00477 is readable, all five coresreport "Examination succeed" (6 breakpoints / 4 watchpoints).
Halting is intermittent. When it works, four cores sit at PC = 0x00029320,CPSR = 0x600001D3, which disassembles to BootMon's tc2_mem_init_wait loop(waiting for the SPC warm-reset register at SCC 0xB88). Reads of 0x7FFF0B88return 0 and 0x1C090018 (UART0 flag register) returns 0xFFFFFFFF.
I am aware of erratum 842119 (ITR instructions from a debugger may mis-executewhen PCLKDBG is much slower than the core clock), and 500 kHz vs 1 GHz is faroutside the safe ratio, so I do not fully trust these readings.
Questions---------1. After CB_nRST is released, is any further DCC handshake required before the A15 fetches from NOR at 0x0? The DCC log ends at "CB_nRST released."2. Does BootMon 5.2.1 depend on anything in SYSTEM.DAT or the DCC flash beyond what the MCC writes?3. Could the BootMon console be routed to a different UART in this configuration?4. Given erratum 842119, what TCK / PCLKDBG ratio is recommended for this target, and is a ULINK2 / CMSIS-DAP usable at all?5. Is this symptom known for any particular PCB revision or A15 r2p1 test-chip batch?
Any hint is welcome. I can provide full serial logs, config files and the exactbinaries used.
