Site
Search
User
Site
Search
User
Forums
Arm 22nm TSMC 22ULL-GL memory power management
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
1 reply
Subscribers
93 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
bernardz
over 2 years ago
Dear Sir or Madam,
I am trying to confirm the potential risk of powering up/down memory. Our soc design implements Arm 22nm TSMC 22ULL-GL memory (TS83Cx00x series). In order to do proper power management with memories, I've being looking into Application Note <Arm Artisan 22nm TSMC 22ULL-GL Memory Power Mangement>. The application note stated clearly that there should be a power supply sequence for VDDCE and VDDPE (when powering up, power up VDDCE first, then VDDPE; when powering down, shut down VDDPE first, then VDDCE). Since such power sequence requires delicated PMU
design
and also have influence to our PMIC spec, I am interested to understand the risk if we powering up/down VDDCE and VDDPE simultaneously?
Thank you for your time and I look forward to hearing from you.
Yours sincerely,
Bernard
Top replies
Ronan Synnott
over 2 years ago
+2
verified
Hello, Please raise an official support case from the Support menu above.
+1
Ronan Synnott
over 2 years ago
Cancel
Vote up
+2
Vote down
Cancel
