Site
Search
User
Site
Search
User
Forums
questions about APB advantages
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
92 subscribers
Views
Users
0 members are here
APB
AMBA
Bus Architecture
Options
More actions
Cancel
Related
jiunyan jiunyan
over 13 years ago
Note: This was originally posted on 8th November 2008 at
http://forums.arm.com
Hi! dear all
Some APB advantages are listed in AMBA 2.0 spec. They are
"¢ performance is improved at high-frequency operation
"¢ performance is independent of the mark-space ratio of the clock
"¢ static timing analysis is simplified by the use of a single clock edge
"¢ no special considerations are required for automatic test insertion
"¢ many Application-Specific Integrated Circuit (ASIC) libraries have a better
selection of rising edge registers
"¢ easy integration with cycle based simulators.
I do not understand these advantages very well.
Especially about
. What dose this description mean? Can anyone tell me if you know? Thanks very much.
0
Colin Campbell
over 13 years ago
Note: This was originally posted on 10th November 2008 at
Hello Jiunyan,
I think all of these points you list are simply down to the fact that the APB only ever uses the rising edges of the PCLK signal.
With regard to the specific point about ATPG you need to clock all the logic being tested using a single clock, so with all logic clocked naturally on the rising edge of the clock, you don't need special test gates to bring in a second "test" clock.
JD
Cancel
Vote up
0
Vote down
Cancel
0
Colin Campbell
over 13 years ago
Hello Jiunyan,
JD
Cancel
Vote up
0
Vote down
Cancel
