Site
Search
User
Site
Search
User
Forums
Confusion over AMBA AHB hsize[] signal definition
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
92 subscribers
Views
Users
0 members are here
AMBA
Bus Architecture
AHB
Options
More actions
Cancel
Related
davemac2 davemac2
over 13 years ago
Note: This was originally posted on 26th February 2008 at
http://forums.arm.com
After reading the AMBA AHB spec rev 2, I am still confused over the relationship of the HSIZE[2:0] signal and the implemented bus width on an interface. If an AHB bus is implemented using 32 bit write and read data buses, I would think this would imply that hsize[2] is essentially unused and always '0' since data transfer width on this bus can only be a byte, half word, or word. Yet, I see interface signal specifications on various 32 bit bus AHB designs where hsize[2] seems to be used and is not optimized out even after synthesis?? My understanding of HSIZE[] and HBURST[] signals is that HBURST[] determines the number of data transfer beats on the bus for a burst transaction whereas HSIZE determines the data width of each transfer. The spec. seems to be vague on this with no examples.
dave mc
0
Colin Campbell
over 13 years ago
Note: This was originally posted on 21st July 2008 at
Hemamth,
Just to correct your reply, if you are using data bus widths of up to 32 (3'b010) or 64 bits (3'b011) wide then HSIZE[1:0] would be sufficient, so it is only once you go above that level when the HSIZE[2] bit would be required.
JD
Cancel
Vote up
0
Vote down
Cancel
0
Colin Campbell
over 13 years ago
Hemamth,
JD
Cancel
Vote up
0
Vote down
Cancel
