Site
Search
User
Site
Search
User
Forums
AXI Cacheable vs. Bufferable
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
92 subscribers
Views
Users
0 members are here
AMBA
AXI
Bus Architecture
Options
More actions
Cancel
Related
Randy Pascarella
over 13 years ago
Note: This was originally posted on 19th November 2007 at
http://forums.arm.com
If an AXI slave acting as a bridge has accepted a bufferable (ACACHE[0]) and cacheable (ACACHE[1]) write and responded with BRESP, is it required to flush this buffered write when later accepting a read from the same AXI master that overlaps but is marked as not cacheable?
In other words, should the cacheable bit be used in determining when bufferable writes should be flushed, or is flushing only required as noted in the spec upon receipt of a non-bufferable write with matching AWID?
0
Randy Pascarella
over 13 years ago
Note: This was originally posted on 20th November 2007 at
I was concerned about the ACACHE[C] bit for the read being set to 0 meaning that the read must not be prefetched. I took this to mean that the read must come from the final destination and not an intermediate bridge that was "caching" the data due to a previous bufferable write.
For example, could a device use a read (non-cacheable) to push a previous bufferable write to its final destination to know when it was safe to assert an interrupt, or would that device be required to use a non-bufferable write to achieve this? It seems to me that using a cacheable read would obtain the new data, but that data could be forwarded by an intermediate bridge. An interrupt could cause a processor to read the final destination and not see the new data due to the processor read taking a different path. Does this make sense?
Also, you bring up a point I was not aware of. You're saying that a bridge taking a bufferable write must take ownership of RAW hazards for all masters, not just the issuing master. Is this required behavior for AXI? Statements about ordering in the spec are master-centric, so I assumed that RAW hazards only applied within a master.
Once again, you've been very helpful. Thanks!!!
Cancel
Vote up
0
Vote down
Cancel
0
Colin Campbell
over 13 years ago
Hi Randy,
I would think that a slave which decides to give a BRESP for a bufferable write before the write data reaches the eventual destination is taking responsibility for any hazard checking for subsequent reads or writes, from the same or different masters.
A non-bufferable write would need to flush the write buffer to maintain the correct system event ordering, but a read could just be handled by forwarding write data from the write buffer if a hit is detected, rather than delaying the master while the write buffer is flushed.
The cacheability (is that a real word ?) of the read shouldn't affect whether the buffer is flushed or not.
Or am I missing a more subtle problem ?
I guess if you wanted to make the system foolproof (and simpler), flushing the write buffer for any subsequent read access would ensure you are accessing the most recent data.
JD
Cancel
Vote up
0
Vote down
Cancel
