Site
Search
User
Site
Search
User
Forums
Basics: C programming for ARM - AHB transfers
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
92 subscribers
Views
Users
0 members are here
AMBA
Bus Architecture
AHB
Options
More actions
Cancel
Related
joewu joewu
over 13 years ago
Note: This was originally posted on 18th September 2007 at
http://forums.arm.com
Would someone please help me about the next basic things?
I have programed microcontrollers in the past but now I need to work with ARM processors and need some basic pieces to connect the puzzle.
I wil write a C/C++ code for ARM966 but I don't know what to do in the code to communicate to an AHB peripheral. It should be memory mapped but I don't know at what location and if I need to do the memory initalisation at the start of the code or I can read it from somewhere - I have not been able so far to find a clear document about that.
Also, I expect that is enough for me to write to that location in the memory and to read from it and the compiler 'armcc' will take care of generating AHB transaction data that will go to ARM AHB interface ports. I am right or there are specific C functions for AHB transfers in both directions?
I expect to have a library of the C functions that I can use in the code but also somehow I couldn't find the place where it is explained.
I have been digging over RealView 3.0 (Unix) directories in the search for that and I see several header files (like rt_heap.h, rt_memory.h and so on) but I don't have any single C project example where I can see their usage.
I would really apreciate if someone can give me some examples or point me to a location where I can read about that.
The same questions go for the tightly coupled memory (TCM) - where is it in the memory map and so on.
Any help is appreciated.
Thank you very much,
joewu
0
Peter Harris
over 13 years ago
As a programmer you don't see the details of the bus protocol (AHB / AXI / etc) - the hardware does all of this for you, so don't worry about it. The compiler will generate "load" and "store" instructions - the ARM core will handle the rest =P
Simply use standard C pointer operations (with appropriate volatile type modifiers) to access data from the hardware peripheral you want to connect to.
Cheers,
I
Cancel
Vote up
0
Vote down
Cancel
0
Peter Harris
over 13 years ago
Cheers,
I
Cancel
Vote up
0
Vote down
Cancel
