Which definition is right for "ne10_addc_float_c"?
On a Get Start thread of this web site, it has a short NE10 example having such snippet:
      ne10_addc_float_c( thedst1 , thesrc, thecst, ARRAY_LENGTH );
      ne10_addc_float_neon( thedst2 , thesrc, thecst, ARRAY_LENGTH );
I install NE10 library. In the documentation, it has a different definition:
ne10_result_t ne10_addc_float_neon (ne10_float32_t *dst, ne10_float32_t *src, const ne10_float32_t cst, ne10_uint32_t count) asm("ne10_addc_float_neon")
I am curious about the last "asm("ne10_addc_float_neon")". Could you tell me that?
Thanks,
  • Excuse me for the previous question. I find that it is caused by the generated documentation, which is wrong after I check the on-line documentation.
    Now, I have a new question when I build another simple example from the right NE10 documentation:
    int main()
         ne10_result_t status;
         printf ("Going to initialize NE10...\n");
         status = ne10_init();
         if (status != NE10_OK)
             printf ("NE10 init failed.\n");
         printf ("NE10 has been initialized.\n");
         test_add1();
         test_add2();
         return 0;
    I find that "
    status = ne10_init();"
    will cause build errors, such as:
    robert@M5100:~/workspace_v5_5/NE10_testHardware0$ arm-linux-gnueabihf-gcc -O2 -o sample testHd.c -I$NE10_INC_PATH -l:$NE10_LIB_PATH/libNE10.a
    /home/robert/projectNe10-Ne10-4167142/build/modules/libNE10.a(NE10_len.c.o): In function `ne10_len_vec2f_c':
    NE10_len.c:(.text+0x5e): undefined reference to `sqrtf'
    /home/robert/projectNe10-Ne10-4167142/build/modules/libNE10.a(NE10_len.c.o): In function `ne10_len_vec3f_c':
    NE10_len.c:(.text+0xf4): undefined reference to `sqrtf'
    /home/robert/projectNe10-Ne10-4167142/build/modules/libNE10.a(NE10_len.c.o): In function `ne10_len_vec4f_c':
    NE10_len.c:(.text+0x18c): undefined reference to `sqrtf'
    I have no idea on how to solve this. Please help me!
  • Hi,
    I would like to add more information about the problem.
    First, the test .c file is from link:
    Project Ne10: File List
    Its path is:
    /home/yang/NE10/NE10_github/Ne10_github_doc/Ne10/samples/NE10_test.c [code]
    Second, it generates an error in test_add1 when compiling.
    00046 void test_add1 (void)
    00047 {
    00048  int i;
    00049 ne10_float32_t thesrc[5];
    00050 ne10_float32_t thecst;
    00051 ne10_float32_t thedst[5];
    00052
    00053  for (i = 0; i < 5; i++)
    00054 {
    00055 thesrc[i] = (ne10_float32_t) rand() / RAND_MAX * 5.0f;
    00056 }
    00057 thecst = (ne10_float32_t) rand() / RAND_MAX * 5.0f;
    00058
    00059  ne10_addc_float (thedst , thesrc, thecst, 5);
    00060 }
    00061
    I have set up the include and library path in the IDE. It seems that it does understand ne10_addc_float in my environment. I originally thought it was a typo. After I changed that to ne10_addcfloat_c, it has the undefined reference errors.
    I also have tried command line for building. It has the same errors.
  • Hi,
    Is there a way to check the included functions inside libNE10.a? I try nm with arm-linux-gnueabihf-nm, but it wants .out input file.
  • Hi,
    As the link: Ne10 Library Getting Started, I build NE10 library again with the following commands:
    $mkdir build
    $cd build
    $cmake
    -DCMAKE_TOOLCHAIN_FILE=../config.cmake ..
    $make
    The generated library is: libNE10.a. I build my project with commands:
    $arm-linux-gnueabihf-ar-gcc –O2 -o sample sample.c  -I$NE10_INC_PATH -l:$NE10_LIB_PATH/libNE10.a
    The undefined reference problem is still there.
    I find that the generated NE10_test_static can run at the target. After some search, I find NE10_test_static uses the following link command under folder (projectNe10-Ne10-4167142/build/samples/CMakeFiles/NE10_test_static.dir) :
    /home/robert/ti-sdk-am335x-evm-06.00.00.00/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf-gcc  -O2 -mthumb-interwork -mthumb -march=armv7-a -mfpu=vfp3CMakeFiles/NE10_test_static.dir/NE10_test.c.o  -o NE10_test_static -rdynamic ../modules/libNE10.a -lm
    It seems that it uses dynamic library. I have not found any way to generate static NE10 library with many options with (ON or OFF)
    LD_LIBRARY_PATH=
    Even after the library path variable is removed, the copied NE10_test_static and my project can run. That is, it does not use the hard drive libNE10.a. I am new to Linux and puzzled by the conflicting facts. I have attached the library, the static test applications and link file. Do you think on my drive libNE10.a is static or dynamic library? How to generate a static libNE10 library?
    Thanks,
  • Hi, Ruwan2,
    >Hi,
    These 2 functions are different functions, but they have same functionality. Generally, the difference is: ne10_addc_float_c is implemented in C and ne10_addc_float_neon is implemented by assembly and optimized by Neon.
    the asm() key word is used to specify the name in generated object file. It is a C extension. You can refer more details at http://gcc.gnu.org/onlinedocs/gcc-4.8.2/gcc/Asm-Labels.html#Asm-Labels.
    >Thanks,
  • <robert@M5100:~/workspace_v5_5/NE10_testHardware0$ arm-linux-gnueabihf-gcc -O2 -o sample testHd.c -I$NE10_INC_PATH -l:$NE10_LIB_PATH/libNE10.a
    </home/robert/projectNe10-Ne10-4167142/build/modules/libNE10.a(NE10_len.c.o): In function `ne10_len_vec2f_c':
    <NE10_len.c:(.text+0x5e): undefined reference to `sqrtf'
    </home/robert/projectNe10-Ne10-4167142/build/modules/libNE10.a(NE10_len.c.o): In function `ne10_len_vec3f_c':
    <NE10_len.c:(.text+0xf4): undefined reference to `sqrtf'
    </home/robert/projectNe10-Ne10-4167142/build/modules/libNE10.a(NE10_len.c.o): In function `ne10_len_vec4f_c':
    <NE10_len.c:(.text+0x18c): undefined reference to `sqrtf'
    <I have no idea on how to solve this. Please help me!
    you should add -lm when you compile your code
  • >I find that the generated NE10_test_static can run at the target. After some search, I find NE10_test_static uses the following link command under folder (projectNe10-Ne10-4167142/build/samples/CMakeFiles/NE10_test_static.dir) :
    The command you supply is NOT using a dynamic library (refer here: http://gcc.gnu.org/onlinedocs/gcc/Link-Options.html for more details about -rdynamic option), it is static linking. You can find related optiones at line 31 and 32 of Ne10 library's root CMakelists.txt (the top CMakelists.txt).
    The libNE10.a is static library. *.a is static library under linux, refer more details: http://en.wikipedia.org/wiki/Static_library.
