Hello Arm graphics team,
We have a pure Android Java EGL14/GLES30 reproduction on moto g 5G (2022), Android 13/API 33, Mali-G57 MC2. Exact driver: OpenGL ES 3.2 v1.r32p1-01eac0.0a0b917d9265b4c01be9925306306139.
After pbuffer grid draws, glFlush alone leads to rapid graphics memory growth and Android low-memory termination after about 25-26 seconds. Adding glFenceSync before that same flush, then immediately calling glDeleteSync, completes 600 seconds with zero grid client waits and zero retained grid sync handles. Immediate deletion does not establish observed GPU completion.
Public source, build/run instructions, source/APK hashes, detailed measurements and graphs:https://github.com/dfdgsdfg/mali-g57-r32p1-pbuffer-repro
The workload has two shared ES3 contexts on IO/raster threads, 24 resident 1200x1200 JPEG textures decoded with Android BitmapFactory, full source readbacks and repeated 24x24 mipmapped crop/read/delete cycles. A 4x6 grid is drawn into a 720x1439 pbuffer. Source uploads use producer fences/flushes; raster waits on each source fence before use. Source textures remain immutable and resident. These source synchronization operations are identical in all cases.
Both cases have swap interval zero, pbuffer eglSwapBuffers and a next-grid interval of at least 16 ms after swap returns. Neither adds a CPU wait for grid GPU completion, an outstanding-grid-frame cap or measured-run glFinish. We understand that pbuffer swap does not imply presentation/completion. No Flutter, Impeller or third-party runtime is included.
In the five-policy test, all four fence variants completed 600 seconds: immediate deletion without polling; retention without polling; zero-timeout polling with retention; and polling with deletion. Flush-only was killed at +26.129 seconds from the first heartbeat. Retaining about 30,000 handles adds a separate CPU allocation cost, rather than the rapid graphics growth.
A second matched pair with identical extra memory telemetry repeated the result:- Immediate deletion: 600 seconds, 85,877 full reads and 30,660 grid frames; last RSS 520.0 MiB, RssFile 327.3 MiB, Android graphics 252.3 MiB.- Flush-only: last heartbeat 24 seconds, 3,244 reads and 1,056 grids; LMK at +25.046 seconds. Last RSS 1,851.7 MiB, RssFile 1,820.2 MiB, graphics 1,784.4 MiB. The kill record reports 1,932,796 kB RSS.
Before/after the final flush-only smaps scan, process RSS was 1,792,448/1,890,900 kB, while summed CPU smaps RSS was only 216,176 kB. Public Motorola r32p1 kernel code accounts nonmapped GPU pages in MM_FILEPAGES/RSS, consistent with this discrepancy; its exact match to installed firmware is unverified. Direct Mali GPU-page telemetry is permission denied. We have not identified the allocation class or distinguished actual physical retention from an accounting defect.
Questions for Arm:1. Is this known in r32p1, and is there an erratum/fixed version or OEM reference?2. Why does an immediately deleted fence change memory behavior when flush alone does not? Does it change render-pass submission or resource retirement?3. Is an explicit fence boundary required for this offscreen workload, and what mitigation is supported?4. Which counters/captures can identify the accumulating GPU allocation on a retail non-root device?
These are single physical trials per policy plus the repeated pair. Telemetry can perturb timing, and there is no independent grid pixel oracle. Readbacks/crops continue until LMK; this is memory termination rather than a retained readback-call hang. We do not claim a confirmed permanent leak or specification violation, or a shared cause with Flutter #193428's original stall or the legacy texture-name erratum.
Does this reproduce on anything newer?Bug reports for a specific device running an older driver should be routed to the OEM - it is likely that fixes already exist in the latest Arm driver, and OEM updates to use newer drivers are out of our control.In general I would expect glFlush() to be a no-op on most implementations though - actual workload submission flushes are inferred from real synchronization. Is there a real use case that submits a lot of GPU work with no other following synchronization to ever consume what the GPU did? It seems a little too synthetic ...
glFlush()
Thank you for the explanation.
I created this native test while investigating the cause of a Flutter/Impeller issue: github.com/.../193428.
Your feedback makes me think the behavior observed in this synthetic pbuffer test may not reflect typical production workloads, and that the original Flutter issue could also involve the Impeller implementation. I’m still working to distinguish the two.
I’ll check whether similar behavior occurs with newer Mali drivers and revisit how the test consumes the final grid output.
Thanks again for your guidance.
While investigating Flutter/Impeller issue #193428, we isolated a readback/bind stall in a standalone Android Java EGL14/GLES30 application, without Flutter or Impeller.
Following the request to check a newer driver, this stall also reproduces on Pixel 6 / Mali-G78 r38p1, beyond the original Motorola / Mali-G57 r32p1 environment
Public source, exact build/run commands, source hashes, and detailed results:
https://github.com/dfdgsdfg/mali-shared-texture-stall-repro
The source is the unchanged tested snapshot. The repository includes the instrumentation harness and a hash-checked downloader for the original public JPEG fixtures.
We compared two conditions using the same APK pair on each physical model:
Only the Raster source selector changes. Both objects are allocated, uploaded with identical pixels, and mipmapped in both cases. A checked producer glFinish completes before publication and consumer use. Sources stay immutable during consumption and retire only after both consumers return. The workload stays within 24 logical pairs / 48 source texture names. There are no application source GLsync operations, client upload waits, or Raster source waits in either condition. Software UI is explicitly observed with hardware acceleration disabled.
glFinish
At each AA endpoint, progress stays unchanged for over 30 seconds:
glReadPixels
glBindTexture
gles_texturep_create_slave
gles_object_master_get_or_create_slave
glescore_submission::reset()
The function names above are from the symbol-bearing Pixel r38p1 capture. The exact IO and Raster TIDs come from the matching generation and first-use trace records. SIGABRT is deliberately sent only after the stable stall to export a tombstone; this is not a spontaneous-crash claim. We have not established the complete private wait cycle.
AB retains matching-generation first-use wrapper overlap as well: 3,143 overlapping pairs on A15 and 4,033 on Pixel. These are host-call intervals, not measurements of GPU or driver-internal concurrency. Both AB workloads complete 600 seconds without a reported GL error.
Exact driver strings:
OpenGL ES 3.2 v1.r32p1-01eac0.3d0f892e790e4319a235910ce1559a8a
7bfa4a8c86009d1d
OpenGL ES 3.2 v1.r38p1-01eac0.1a610aadd6bd0e3c95c856461c1c5ef1
16006f8d22c8c796
Each model's reported firmware and GLES version match between AA and AB. There is one trial per condition/model; the finite AB passes do not establish prevention. Pixel provides a non-MediaTek comparison, but I am not assigning exclusive ARM-versus-OEM responsibility from these results alone.
Thank you for reviewing the reproducer.
