I'm trying to use Mali Offline Compiler to build a more accurate runtime GPU workload estimation for our game.
I have a shader with a loop whose iteration count comes from a CPU-provided uniform/constant buffer, for example:
uniform int lightCount; for (int i = 0; i < lightCount; ++i) { ProcessLight(i); }
For a specific draw call, the CPU knows the actual value, for example:
lightCount = 2
What I would like to estimate is the Mali Offline Compiler cycle cost for the original compiled shader executing this loop exactly twice, especially the per-functional-unit costs:
A / LS / V / T cycles
The problem is that Mali Offline Compiler does not know the runtime uniform value. For a uniform-controlled loop, the Longest Path Cycles can also be reported as N/A.
I tried replacing the runtime value with a compile-time constant, for example:
const int lightCount = 2;
However, this changes the compiler optimization. In my tests, the generated shader uses a different number of work registers, presumably due to optimizations such as loop unrolling, constant propagation, dead-code elimination, and different register allocation.
Therefore, the result from the specialized shader is not necessarily representative of the original shader executing with lightCount = 2 at runtime.
What I am looking for is something conceptually like:
Original compiled shader + Known runtime uniform values ↓ Path-aware performance analysis ↓ A / LS / V / T cycles
without recompiling/specializing the shader in a way that changes its register usage or occupancy.
Is there any supported way to do this with Mali Offline Compiler?
In particular:
Can Mali Offline Compiler expose cycle costs at a finer granularity, such as per basic block, loop body, or control-flow region?
If so, we could keep the original compiled shader and calculate something like:
base cost + loop body cost × runtime iteration count + loop control overhead
Our goal is not necessarily to predict the final GPU execution time directly. We are mainly trying to estimate the shader-core workload in terms of the same A / LS / V / T cycle metrics reported by Mali Offline Compiler, while preserving the register usage and occupancy of the original shader.
Thanks!
