【Vulkan】 Question About VK_EXT_fragment_density_map
About VK_EXT_fragment_density_map(VkPhysicalDeviceFragmentDensityMapFeaturesEXT) (registry.khronos.org/.../vkspec.html
when used VK_EXT_fragment_density_map , mali gpu (Device1 & Device2) has crashed In vkCmdEndRenderPass (crash stack in attachment , No Validation Error),and Adreno  gpu (Device3) has succeed
Device1(mali)
  •  Oppo Reno5 Pro 5G
  •  GpuFamily:ARM Mali-G77 MC9
  •  AndroidVersion:12
  • GlVersion:OpenGL ES 3.2 v1.r32p1-01eac0.111ce79c0e85a639772bd634d9e734cf,)
  • VulkanVersion: 1.1.177
Device2(mali)
  • GpuFamily: Mali-G77 MC9
  • AndroidVersion: 11
  • GlVersion: OpenGL ES 3.2 v1.r26p0-01eac0.bed3b8f44871361148086fa6397ba747
  • VulkanVersion: 1.1.131
Device3(Adreno)
  • vivo
  • GpuFamily: Adreno (TM) 660
  • GlVersion: OpenGL ES 3.2 V@0525.0 (GIT@f7fceaaafa, I5121de8c99, 1605177106) (Date:11/12/20)
  • VulkanVersion: 1.1.128
Code Setting:
  1. VK_EXT_fragment_density_map be Supported (By vkEnumerateDeviceExtensionProperties)
  2. VkPhysicalDeviceFragmentDensityMapFeaturesEXT.fragmentDensityMap is true (By vkGetPhysicalDeviceFeatures2)
  3. When create device, I added extension VK_EXT_fragment_density_map (Supported By Device) (means VkDeviceCreateInfo.ppEnabledExtensionNames = "xxx"...,"VK_EXT_fragment_density_map",..."") & pNext to VkPhysicalDeviceFragmentDensityMapFeaturesEXT (means VkDeviceCreateInfo.pNext = ... &VkPhysicalDeviceFragmentDensityMapFeaturesEXT ....)
Is  Vulkan driver (mali)  bug ?
11-15 11:23:35.249 25220 25220 E DEBUG   : failed to read /proc/uptime: Permission denied
--------- beginning of crash
11-15 11:23:35.460 25220 25220 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
11-15 11:23:35.460 25220 25220 F DEBUG   : Build fingerprint: 'OPPO/PDSM00/OP4EA3:12/SP1A.210812.016/R.202210172234:user/release-keys'
11-15 11:23:35.461 25220 25220 F DEBUG   : Revision: '0'
11-15 11:23:35.461 25220 25220 F DEBUG   : ABI: 'arm64'
11-15 11:23:35.461 25220 25220 F DEBUG   : Timestamp: 2022-11-15 11:23:35.249080644+0800
11-15 11:23:35.461 25220 25220 F DEBUG   : Process uptime: 0s
11-15 11:23:35.461 25220 25220 F DEBUG   : Cmdline:
11-15 11:23:35.461 25220 25220 F DEBUG   : pid: 24814, tid: 24923, name: GameThread  >>>  <<<
11-15 11:23:35.461 25220 25220 F DEBUG   : uid: 10359
11-15 11:23:35.461 25220 25220 F DEBUG   : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0
11-15 11:23:35.461 25220 25220 F DEBUG   : Cause: null pointer dereference
11-15 11:23:35.461 25220 25220 F DEBUG   :     x0  00000076f3d435e8  x1  0000000000000000  x2  0000000000000002  x3  00000076f3d43660
11-15 11:23:35.461 25220 25220 F DEBUG   :     x4  0000000000000000  x5  0000000000000000  x6  0000000000000000  x7  0000000000000000
11-15 11:23:35.461 25220 25220 F DEBUG   :     x8  00000076df66b6cc  x9  0000000000000000  x10 00000076f3d43c28  x11 0000000000000018
11-15 11:23:35.461 25220 25220 F DEBUG   :     x12 00000075d657c428  x13 0000000000000003  x14 0000000000000000  x15 0000005efcb90780
11-15 11:23:35.461 25220 25220 F DEBUG   :     x16 00000076e18a8878  x17 00000077a1b5c9b0  x18 472e736c69745565  x19 00000076f3d43808
11-15 11:23:35.461 25220 25220 F DEBUG   :     x20 0000000000000020  x21 00000076f3d43b80  x22 00000076f3d43690  x23 0000005efcb90a60
11-15 11:23:35.461 25220 25220 F DEBUG   :     x24 00000076f3d43660  x25 00000076f3d43630  x26 0000005efcb90640  x27 0000000000000020
11-15 11:23:35.461 25220 25220 F DEBUG   :     x28 000000760107cf98  x29 0000007619adb5d0
11-15 11:23:35.461 25220 25220 F DEBUG   :     lr  00000076dfcf36d8  sp  00000076f3d435a0  pc  00000076dfcf3720  pst 0000000040001000
11-15 11:23:35.461 25220 25220 F DEBUG   : backtrace:
11-15 11:23:35.461 25220 25220 F DEBUG   :   NOTE: Function names and BuildId information is missing for some frames due
11-15 11:23:35.461 25220 25220 F DEBUG   :   NOTE: to unreadable libraries. For unwinds of apps, only shared libraries
11-15 11:23:35.461 25220 25220 F DEBUG   :   NOTE: found under the lib/ directory are readable.
11-15 11:23:35.461 25220 25220 F DEBUG   :   NOTE: On this device, run setenforce 0 to make the libraries readable.
11-15 11:23:35.461 25220 25220 F DEBUG   :       #00 pc 000000000082e720  /vendor/lib64/egl/libGLES_mali.so (BuildId: 2ec4b9d18b1e2317)
11-15 11:23:35.461 25220 25220 F DEBUG   :       #01 pc 00000000008353a0  /vendor/lib64/egl/libGLES_mali.so (BuildId: 2ec4b9d18b1e2317)
11-15 11:23:35.461 25220 25220 F DEBUG   :       #02 pc 00000000007f3100  /vendor/lib64/egl/libGLES_mali.so (BuildId: 2ec4b9d18b1e2317)
11-15 11:23:35.461 25220 25220 F DEBUG   :       #03 pc 00000000007f2bf8  /vendor/lib64/egl/libGLES_mali.so (BuildId: 2ec4b9d18b1e2317)
11-15 11:23:35.461 25220 25220 F DEBUG   :       #04 pc 00000000006b1270  /vendor/lib64/egl/libGLES_mali.so (BuildId: 2ec4b9d18b1e2317)
11-15 11:23:35.461 25220 25220 F DEBUG   :       #05 pc 00000000006b10b8  /vendor/lib64/egl/libGLES_mali.so (BuildId: 2ec4b9d18b1e2317)
11-15 11:23:35.461 25220 25220 F DEBUG   :       #06 pc 00000000010c5184  /data/app/~~cI-LhU7Wz4s5-KcFdGVjAQ==/rFJW-NxE6IGXUw4s6jjX5w==/lib/arm64/libVkLayer_khronos_validation.so (BuildId: c2ad5fb544be299babc18300b749b6fbf5f92b43)
