Connection refused when connecting to xx , Problem reading the trace version: 'Read timed out'.
When I try to connect the device in Graphics Analyzer, I encountered a problem:
Connection refused when connecting to HUAWEI PCT-AL10.
I didn't root my device and follow the advice
LOG:
Device: HUAWEI PCT-AL10 (5ENDU19218000728, usb:336592896X)
Description: Connect to the device
Result: com.arm.mgd.core.adb.IADBTask$ADBExecutionException: Could not connect to device
at com.arm.mgd.core.adb.AndroidConnector.lambda$0(AndroidConnector.java:87)
at com.arm.mgd.core.adb.AndroidConnector.lambda$2(AndroidConnector.java:155)
at com.arm.mgd.core.adb.AndroidBridgeTask.run(AndroidBridgeTask.java:51)
at com.arm.mgd.core.adb.ADBTaskManager.executeTask(ADBTaskManager.java:492)
at com.arm.mgd.core.adb.ADBTaskManager.lambda$9(ADBTaskManager.java:433)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at com.arm.mgd.core.util.executors.NamedThreadPoolExecutor.lambda$0(NamedThreadPoolExecutor.java:60)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Command 0: "/Users/mg/Library/Android/sdk/platform-tools/adb" version
Exit code: 0
Output:
Android Debug Bridge version 1.0.41
Version 29.0.1-5644136
Installed as /Users/mg/Library/Android/sdk/platform-tools/adb
Command 1: "/Users/mg/Library/Android/sdk/platform-tools/adb" -s usb:336592896X start-server
Exit code: 0
Output:
Command 2: "/Users/mg/Library/Android/sdk/platform-tools/adb" devices -l
Exit code: 0
Output:
List of devices attached
5ENDU19218000728       device usb:336592896X product:PCT-AL10 model:PCT_AL10 device:HWPCT transport_id:1
Command 3: "/Users/mg/Library/Android/sdk/platform-tools/adb" -s usb:336592896X shell am startservice -n com.arm.mgd.androidapp/.applist.DaemonLauncherService
Exit code: 0
Output:
Starting service: Intent { cmp=com.arm.mgd.androidapp/.applist.DaemonLauncherService }
Command 4: "/Users/mg/Library/Android/sdk/platform-tools/adb" -s usb:336592896X shell dumpsys activity services com.arm.mgd.androidapp/.applist.DaemonProxyService
Exit code: 0
Output:
ACTIVITY MANAGER SERVICES (dumpsys activity services)
  User 0 active services:
  * ServiceRecord{d0a2b18 u0 com.arm.mgd.androidapp/.applist.DaemonProxyService}
    intent={cmp=com.arm.mgd.androidapp/.applist.DaemonProxyService}
    packageName=com.arm.mgd.androidapp
    processName=com.arm.mgd.androidapp
    baseDir=/data/app/com.arm.mgd.androidapp-ZYRisZWp8Y76A8oxH4xHNA==/base.apk
    dataDir=/data/user/0/com.arm.mgd.androidapp
    app=ProcessRecord{9dd9ce 25690:com.arm.mgd.androidapp/u0a168}
    isForeground=true foregroundId=1 foregroundNoti=Notification(channel=null pri=0 contentView=com.arm.mgd.androidapp/0x1090096 vibrate=null sound=null defaults=0x0 flags=0x62 color=0x00000000 vis=PRIVATE)
    createTime=-18h25m30s889ms startingBgTimeout=-18h25m15s886ms
    lastActivity=-18h25m30s889ms restartTime=-18h25m30s889ms createdFromFg=false
    startRequested=true delayedStop=false stopIfKilled=false callStart=true lastStartId=1
Command 5: "/Users/mg/Library/Android/sdk/platform-tools/adb" devices -l
Exit code: 0
Output:
Command 6: "/Users/mg/Library/Android/sdk/platform-tools/adb" forward --list
Exit code: 0
Output:
Command 7: "/Users/mg/Library/Android/sdk/platform-tools/adb" -s usb:336592896X forward tcp:61005 tcp:5002
Exit code: 0
Output:
61005
Command 8: "/Users/mg/Library/Android/sdk/platform-tools/adb" forward --list
Exit code: 0
Output:
5ENDU19218000728 tcp:61005 tcp:5002
Command 9: "/Users/mg/Library/Android/sdk/platform-tools/adb" -s usb:336592896X shell setprop debug.vulkan.layers VK_LAYER_ARM_AGA:
Exit code: 0
Output:
LogCat
07-26 16:39:44.093 20780 20856 I chatty  : uid=10172(com.mg.ArmAndroidTest) UnityGfxDeviceW identical 1 line
07-26 16:39:44.113 20780 20856 D         : addLayerName, tid:20856
07-26 16:39:44.127 20988 20988 I GA Daemon Launcher: Received start id 3: Intent { cmp=com.arm.mgd.androidapp/.applist.DaemonLauncherService }
07-26 16:39:44.127 20988 20988 I GA Daemon Launcher: Send data to host: true
07-26 16:39:44.127 20988 20988 I GA Daemon Launcher: Headless mode: false
07-26 16:39:44.128 20780 20856 D         : addLayerName, tid:20856
07-26 16:39:44.146 20780 20856 D         : addLayerName, tid:20856
07-26 16:39:44.147   649   649 I AISched FPS: currentfps 60,detected fps 60,flag 0,high 14,low 4,sleepPercent 0.889536,old 8,new 8
07-26 16:39:44.153 22200 22200 W dumpsys : type=1400 audit(0.0:876030): avc: denied { read } for name="pipe-max-size" dev="proc" ino=20415873 scontext=u:r:shell:s0 tcontext=u:object_r:proc_pipe_conf:s0 tclass=file permissive=0
07-26 16:39:44.158  1374  2873 I ActivityManager: Start dump, calling from : pid=22200, uid=2000
07-26 16:39:44.161 20780 20856 D         : addLayerName, tid:20856
  • logcat:
  • Hi minggoddess,
    Make sure your Android application is compiled using targetSdkVersion 25 or lower, as per the FAQ entry here:
    * https://developer.arm.com/tools-and-software/graphics-and-gaming/arm-mobile-studio/support/faq
    We have a workaround here:
    * https://community.arm.com/developer/tools-software/graphics/b/blog/posts/graphics-analyzer-android-sdk-26
    ... but it only works on some Android devices with the current aga-daemon application (it doesn't work on most Huawei phones). We'll be changing how the daemon communicates with the host in the next Mobile Studio release which should solve this one.
    Cheers,
    Pete
