Site
Search
User
Site
Search
User
Forums
Memory not free after glDeleteTextures call
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
OpenGL ES
Mali-GPU
Mali-400
Options
More actions
Cancel
Related
Sebastien Baudouin
over 13 years ago
Note: This was originally posted on 25th April 2013 at
http://forums.arm.com
Hi ,
i'm using MALI-400 and its OpenGLES stack. Playing with textures, i discovered that the memory used by textures is not free just after glDeleteTextures call.
It seems also the same when using eglImages.
I would expect that just after the call to glDeleteTextures or eglDestroyImageKHR the memory used by the process using openGL decrease. But it is not the case.
Is there a possibility (API) to force the OpenGLES stack to free the memory and give it back to the system ?
Thanks for your help.
BR
Seb
Peter Harris
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Sebastien Baudouin
over 13 years ago
Note: This was originally posted on 26th April 2013 at
thanks for looking at my post.
when i'm deleting the texture i'm sure it is the last context using it and also that any draw is finished (texture is no more used). I also tried to add a glFlush and again nothing changed. The memory is still used or at least assign to my thread. The problem i have is that i'm using lot of texture and a time by thread seems to own lot of memory while it is only using one texture.
I still don't understand why/how the texture memory is not freed ? May be the GL stack is having its own allocator and so the memory is kept by the GL stack even if my app is not using it. If it is the case then i'm wondering how to force it to release the memory.
BR
Seb
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Does the memory footprint drop after a glFinish (glFlush doesn't wait for rendering to complete, so the resource may still be referenced)?
Usual caveat - calling glFinish is normally "very slow" because it forces a pipeline drain of the whole rendering pipe - so it isn't something you want to do often.
Cancel
Vote up
0
Vote down
Cancel
Sebastien Baudouin
over 13 years ago
Note: This was originally posted on 29th April 2013 at
i made a try adding gLFinish and it seems that the memory is not a freed for operation like:
- glDeleteTextures
- eglDestroyImageKHR
- glDeleteBuffers
BR
Seb
Cancel
Vote up
0
Vote down
Cancel
Sebastien Baudouin
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
