Site
Search
User
Site
Search
User
Forums
How to use Mali to convert YUV to RGB32
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
Mali-300
Mali-GPU
Options
More actions
Cancel
Related
james zhang
over 13 years ago
Note: This was originally posted on 17th November 2012 at
http://forums.arm.com
[font=文泉驿正黑][size=2][font=arial, verdana, tahoma, sans-serif][size=2]Hi all,
[/size][/font]
In FirefoxOS, there is a Cubevid application. It use vp8 software codec and the performance is not well.
We use DS5 to find the hot spot, YUV convert to RGB32. You can see [size=2]FastConvertYUVToRGB32Row_C@[/size][size=2]yuv_row_c[/size][size=2].cpp[/size][size=2] in attachment[/size] .
Can you help me to use GPU(Mali300) to convert YUV to RGB?
Thanks for your help!
You can get FFOS code as below.
git clone git://github.com/mozilla/releases-mozilla-central
BR
James[/size][/font]
james zhang
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Chris Varnsverry
over 13 years ago
Note: This was originally posted on 19th November 2012 at
Hi Jameszhang,
Can I ask what hardware you're currently targeting? Also is there any reason you're not using
NEON
for this purpose, as it seems a good fit for this use case? For example I believe the
webm project
have an existing neon implementation of the VP8 codec (
http://code.google.com/p/webm/source/browse/vp8/?repo=libvpx&name=sandbox/jkoleszar/new-rate-control#vp8%2Fdecoder%2Farm%2Fneon
Thanks,
Chris
Cancel
Vote up
0
Vote down
Cancel
james zhang
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Chris Varnsverry
over 13 years ago
Note: This was originally posted on 20th November 2012 at
Hi James,
This post
has some sample shader code for this purpose. You would need to push the YUV data as a texture to the GPU.
Let me know if this helps or if you need any more guidance.
Thanks,
Chris
Cancel
Vote up
0
Vote down
Cancel
james zhang
over 13 years ago
Note: This was originally posted on 21st November 2012 at
Hi Chris,
I found a chrome patch which optimizes YUV2RGB performance by NEON assembly,
http://code.google.com/p/chromium/issues/detail?id=71403
. The major hotspot "FastConvertYUVToRGB32Row_C" reduced quite a lot from 23% to 3%. But we still have some audio clipping during the video play.
So I will try the shader code.
James
Cancel
Vote up
0
Vote down
Cancel
