Site
Search
User
Site
Search
User
Forums
Tips & Tricks: OpenGL vs. OpenGL ES
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
OpenGL ES
Mali-GPU
Options
More actions
Cancel
Related
guestposter guestposter
over 13 years ago
Note: This was originally posted on 15th October 2009 at
http://forums.arm.com
As we come up with various tips and hints that might help application developers working on Mali GPUs we will be posting them here so that you have instant access to them prior to the hints being turned into formal knowledgebase articles or other documentation.
If there are questions that you have, we will do our best to answer them in a timely manner.
This first topic will cover general differences between coding for the OpenGL (desktop graphics library) and OpenGL ES (embedded system graphics library) APIs from Khronos...
over 13 years ago
Note: This was originally posted on 27th October 2009 at
Some differences between OpenGL & OpenGL ES APIs:
OpenGL ES 1.1 and 2.0 are subsets of the full OpenGL standard. Some OpenGL functionality is not available in OpenGL ES:
No support for glBegin or glEnd. Instead, use vertex arrays and vertex buffer objects
Supported rasterization primitives are points, lines and triangles. Quads are not supported
There is no polynomial evaluation stage
Blocks of fragments can be sent directly to individual fragment operations
There is no support for display lists
For complete list, visit [url="
http://www.khronos.org/opengles/
http://www.khronos.org/opengles/[/url]
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
If you are writing code to run on both OpenGL 2.0 and OpenGL ES 2.0, be aware of slight differences between the shader languages used in the two APIs. For example, OpenGL ES 2.0 requires a precision declaration in the fragment shader code, while OpenGL 2.0 does not support this.
To enable your code to run on both OpenGL 2.0 and OpenGL ES 2.0, start every fragment shader with:
[font="Courier New"]#ifdef GL_ES
precision mediump float;
#endif[/font]
Cancel
Vote up
0
Vote down
Cancel
Sara Johnson
over 13 years ago
Note: This was originally posted on 10th July 2011 at
Ahh glad I came to this thread. Once I used [font=arial, sans-serif][size=2]vertex arrays and vertex buffer objects this immediately fixed some of the issues I was having.[/size][/font]
Cancel
Vote up
0
Vote down
Cancel
