Site
Search
User
Site
Search
User
Forums
Drivers for Performance Analysis Tool (Mali 400)
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
Mali Drivers
OpenGL ES
Mali-GPU
Mali-400
Options
More actions
Cancel
Related
Sertac Olgunsoylu
over 13 years ago
Note: This was originally posted on 3rd October 2011 at
http://forums.arm.com
Hi All,
I am a little bit confused about this driver issue. I want to use Performance Analysis Tool. In optimization guide it is stated that in order to collect hw counter data it is necessary to use instrumented drivers. Also it is stated that these drivers are vendor provided. Is it possible to use Mali GPUs Linux Device Drivers r2p0-05rel0 to do that?
Thanks in advance
Pete
over 13 years ago
Note: This was originally posted on 4th October 2011 at
the instrumentation part is implemented in the userspace libraries, e.g. libGLESv2.so, so you need your vendor to supply you with binary libraries for your device built to support instrumentation. The kernel module (mali.ko) is not affected by instrumentation and can remain unchanged.
HTH, Pete
Cancel
Vote up
0
Vote down
Cancel
Sertac Olgunsoylu
over 13 years ago
Thanks Pete.
To run an app in instrumented mode, I need to use only those userspace libraries supplied by vendor, right? Let's say I have a phone and i want to do some instrumentation on my app to take some GPU measurements the only thing I need to do using userspace instrumented drivers (*.so libraries).
I hope I did not get it wrong.
Cancel
Vote up
0
Vote down
Cancel
Pete
over 13 years ago
Note: This was originally posted on 6th October 2011 at
that is correct.
Cheers, Pete
Cancel
Vote up
0
Vote down
Cancel
