Site
Search
User
Site
Search
User
Forums
Getting Mali Graphics Debugger to run with Samsung S2
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
OpenGL ES
Options
More actions
Cancel
Related
Bodo Pfeifer
over 13 years ago
Note: This was originally posted on 6th June 2013 at
http://forums.arm.com
we like to use the Mali Graphics Debugger with a Samsung S2.
There is a problem:
According to the readme we have to copy 2 files to the device.
* Pushing them to /sdcard/ works fine
but
* cp mgddaemon /system/bin/mgddaemon fails
Message: "cp: can't create '/system/bin/mgddaemon': Read-only file system
FYI: I am super user. Tried to chmod the directory but this gives me the same message.
Can anyone help me here?
Thanks in advance,
Bodo
Pete
over 13 years ago
Note: This was originally posted on 7th June 2013 at
Hi Bodo,
it might be that the partition on which the "bin" directory resides is mounted read-only, in which case even root (superuser) can't write until it is remounted read-write.
If you did something like
adb shell
to open a shell on the device, and then
mount
you can see what partitions are mounted. If there is one listed for "system" then you could try something like this (once you have become superuser):
mount -o remount, rw /system
If "system" isn't listed in the mounted partitions then you may need to remount the whole root filesystem read-write instead:
HTH, Pete
Cancel
Vote up
0
Vote down
Cancel
Bodo Pfeifer
over 13 years ago
Hi Pete,
thanks for this tip. It worked! Got those files copied and could continue with the readme.
Now I get a connection.
The Log of the Debugger says "[INFO]: PROCESS_STARTED" when I start the game.
The main window keeps showing "No trace data to display". Not sure if this is normal.
If I push the button to capture a frame, the log states: "[INFO]: FRAME_CAPTURE_WAITING".
And instantly a dialogue pops up, telling me that "An internal error occured during: "Capturing frame"."
The more-details button then shows an java.lang.NullPointerException.
I have no idea what might be wrong here. The app is a release build, might this be a problem? Does the app need to be debuggable?
Or is this truly an internal error from the Debugger?
Can you / anyone help me here?
Thanks in advance,
Bodo
Cancel
Vote up
0
Vote down
Cancel
Chris Varnsverry
over 13 years ago
Note: This was originally posted on 10th June 2013 at
Hi Bodo,
Sorry to hear you're having trouble with the tool. Can you let me know which version of Android you are using? Also which application are you attempting to trace, and are you sure it's a GLES application?
Thanks,
Chris
Cancel
Vote up
0
Vote down
Cancel
