Site
Search
User
Site
Search
User
Forums
Mali gpu texture compression for Linux
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
Mali-GPU
Mali Texture Compression Tool
Options
More actions
Cancel
Related
bogdan d
over 13 years ago
Note: This was originally posted on 14th January 2013 at
http://forums.arm.com
The complete output is: WARNING: Error compressing ("/home/../carpetHalved_atlas.png"): "Error: Could not convert input image /home/../carpetHalved_atlas.png to .ppm" The png is the same one as used in Mali SDK for android. It does not work with any combination of settings, or other png files.
As I don't see any other useful error info, I don't really know which is the reason for it. On a windows system it seems to work. It fails on an Ubuntu 12.04.
Could you help me with it?
Thank you,
Bogdan
Rhys Copeland
over 13 years ago
Hey Bogdan!
The chances are that this error is generated because the compressor can't find ImageMagick's "convert" utility. Are you using the GUI or just the command-line tool? If it's the GUI, could you check the application's preferences and ensure you've set the correct path to convert?
Cancel
Vote up
0
Vote down
Cancel
Rhys Copeland
over 13 years ago
Hey Bogdan!
Cancel
Vote up
0
Vote down
Cancel
