Site
Search
User
Site
Search
User
Forums
Offline compiler issues
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
OpenGL ES
Mali-GPU
Options
More actions
Cancel
Related
Stuart Russell
over 13 years ago
Note: This was originally posted on 22nd November 2011 at
http://forums.arm.com
We've been running into issues using the offline compiler on Eclipse 3.7.1. The OpenGLES Emulator version 1.3 is installed, as is the Mali GPU Offline Shader Compiler v2.2. The offline compiler is set and enabled within the 'compiler' settings of 'Mali GPU Shader Development Studio', but the syntax checking never occurs. Forcing an error into a fragment results only in rendering not working, no details in "Problems" or any highlights within the code segment as described in the installation notes.
Any suggestions as to what else to try / look for would be appreciated.
Lorenzo Dal Col
over 13 years ago
Note: This was originally posted on 23rd November 2011 at
which operative system are you working on?
Thanks,
Lorenzo
Cancel
Vote up
0
Vote down
Cancel
Stuart Russell
over 13 years ago
This is running on Windows 7 32 bit version.
Good news: The problem was solved this morning by adding the compilers location to the path environment variable. Once added, it was picked up right away.
Cheers!
Thanks,
Lorenzo
Cancel
Vote up
0
Vote down
Cancel
paddy smith
over 13 years ago
Note: This was originally posted on 8th March 2012 at
I have a newbie.I have registered for the purpose of learn.
your doubt is boost of my mind..
Thanks to sharing .....
Cancel
Vote up
0
Vote down
Cancel
