Site
Search
User
Site
Search
User
Forums
Help,OpenGL ES Emulator 1.3 Demo can not run on my laptop!
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
OpenGL ES
Options
More actions
Cancel
Related
cm cm
over 13 years ago
Note: This was originally posted on 17th September 2011 at
http://forums.arm.com
My system is ubuntu 11.04, videocard X700, OpenGL version string: 2.1 Mesa 7.12-devel.
I had compiled the demo cube with debug. when it running ,report the error info:
Debug source START:
* This proprietary software may be used only as
* authorised by a licensing agreement from ARM Limited
* (C) COPYRIGHT 2009 - 2011 ARM Limited
* ALL RIGHTS RESERVED
* The entire notice above must be reproduced on all authorised
* copies and copies may only be made to the extent permitted
* by a licensing agreement from ARM Limited.
attribute vec4 av4position;
attribute vec3 av3colour;
uniform mat4 mvp;
varying vec3 vv3colour;
void main() {
vv3colour = av3colour;
gl_Position = mvp * av4position;
Debug source END
Log START:
sh: malisc: not found
Log END
any help will be thanks!!!!!
cm cm
over 13 years ago
Note: This was originally posted on 20th September 2011 at
Hi Anthnoy, Thanks for reply. I download the malisc and put it into /usr/bin.
When I try the cube demo, it report error, I can't find the MACRO strarting with GL_
Debug source START:
uniform mat4 mvp;
void main() {
Debug source END
Log START:
0:2(9): preprocessor error: Macro names starting with "GL_" are reserved.
Log END
Cancel
Vote up
0
Vote down
Cancel
cm cm
over 13 years ago
Note: This was originally posted on 21st September 2011 at
Hi Anthnoy,I want to try that switch to mesa 7.7.1.
But I dont know how to do it on ubuntu. Can you give some advice?
Cancel
Vote up
0
Vote down
Cancel
Jonathan Kirkham
over 13 years ago
Note: This was originally posted on 23rd November 2011 at
We believe we have now fixed this issue.
Could you please try the latest version of the Emulator (v1.3.1) and see if that solves the problem for you.
http://www.malideveloper.com/developer-resources/tools/opengl-es-20-emulator.php
Thanks,
Jon
Cancel
Vote up
0
Vote down
Cancel
