Site
Search
User
Site
Search
User
Forums
OpenGL ES 2.0 Emulator
Jump...
Cancel
Locked
Locked
Replies
Subscribers
136 subscribers
Views
Users
0 members are here
OpenGL ES
Options
More actions
Cancel
Related
Terry Butler
over 13 years ago
Note: This was originally posted on 11th July 2011 at
http://forums.arm.com
Using a modern "Intel HD Graphics" integrated graphics and although OpenGL Extensions Viewer (v3.3.7) claims that I have a full 2.1 compatibility with 82% 3.0 compatibility, I am getting the following EGL_NOT_INITIALIZED error on eglinitialize(...):
eglGetError() = 12289 (0x00003001) at line 223
I've looked high and low for a solution about this but haven't turned anything up. I did see the question posted in another post asking for the following extensions:
Yes WGL_ARB_extensions_string
Yes WGL_ARB_pixel_format
Yes WGL_ARB_pbuffer
No WGL_ARB_render_texture
Yes EXT_framebuffer_object.
Does eglInitialize() need all extensions available or else it'll fail? Can I perhaps override this and use extensions on an if-need basis?
Many Thanks.
Wasim Abbas
over 13 years ago
Note: This was originally posted on 12th July 2011 at
Hi terryjb,
Can you please let us know what Operating System you are working on?
Our Emulator needs the mentioned extensions. elgInitialize() will return with EGL_NOT_INITIALIZED if any one of the extensions is missing. The latest version no longer needs WGL_ARB_render_texture.
At the moment there is no easy way of overriding this behaviour.
Kind Regards,
Wasim
Cancel
Vote up
0
Vote down
Cancel
Terry Butler
over 13 years ago
Hi Wasim,
Thanks for the response!
I'm running on Windows 7 64-bit, using v1.3.0 milestone 1 of the emulator.
I've attached the output from the extensions viewer.
Thanks.
Cancel
Vote up
0
Vote down
Cancel
