Armlm CID different from License manager CID
I'm trying to convert my UBL license to a node-locked license in order to use Arm compiler v5. I'm following this doc https://developer.arm.com/documentation/102516/1-3/User-based-licensing-overview/Backwards-compatibility
The LIC is generated correctly, but when I try to add in the License Manager I get: *** ERROR R208(1): RENEW LICENSE ID CODE (LIC)
This means:
This error can occur if:
  • Your LIC has been modified since it was generated. Did you incorrectly copy it?
  • Some of the computer parameters have changed since you generated your LIC.
Looking at the CID when generating the LIC with armlm genlic, this doesn't match the CID in the License Manger.
How can I fix this? I'm running Arm tools on Windows in a virtual machine with internet connectivity.
