MDK-Toolbox Toolchain Issue when using legacy compiler for armasmHello Folks!
I am not sure if i am right here in this forum but, I stepped over an issue with the MDK-Toolbox adding an option not recognized by the armclang compiler.It is used in a GitLab CI Pipeline for automating - Conversion (from µvision, uvprojx => csolution)- Compiling and Linking- Testing- MergeSpecs:- Ubuntu Docker Image- VCPKG - MDK-Toolbox 1.1.0 - CMake 3.31.5 - Ninja 1.12.0 - armclang 6.23.0 - CMSIS-Toolbox 2.8.0Commands used:- uv2csolution $UVPROJX_FILE- cbuild $CSOLUTION_FILE --packs --update-rte --verbose Occured Error:FAILED: CMakeFiles/Group_Application_MDK-ARM.dir/ProjectX/MDK-ARM/startup_stm32l452xx.o/root/.vcpkg/downloads/artifacts/2139c4c6/compilers.arm.armclang/6.23.0/bin/armclang -DSTM32L452xx -D_RTE_ -D__MICROLIB -I/ProjectX/MDK-ARM/RTE/_ProjectX -I/root/.cache/arm/packs/ARM/CMSIS/6.1.0/CMSIS/Core/Include -I/root/.cache/arm/packs/LVGL/lvgl/9.3.0-dev2 -I/root/.cache/arm/packs/LVGL/lvgl/9.3.0-dev2/src/core -mcpu=Cortex-M4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard --target=arm-arm-none-eabi -c -mlittle-endian -masm=auto -g -O1 -masm=auto "-x assembler" -c -o CMakeFiles/Group_Application_MDK-ARM.dir/ProjectX/MDK-ARM/startup_stm32l452xx.o /ProjectX/MDK-ARM/startup_stm32l452xx.Sarmclang: error: language not recognized: ' assembler'Please note the space "' a" between "'" and "a".Workaround:After many test, I figured out, the uv2csolution conversion creates a ProjectX.cproject.yml with the line "- -x assembler".Therefore i removed this line with "sed", so the "cbuild" command does not run in an issue any more.Now the the cbuild compiles and links the project successful.The section created by uv2csolution looks like:"groups: - group: Application/MDK-ARM files: - file: startup_stm32l452xx.s misc: - ASM: - -masm=auto - -x assembler"Expected Behavior:Warning for using legacy compiler like:"A1950W: The legacy armasm assembler is deprecated. Consider using the armclang integrated assembler instead."Questions:Am I right to suspect the conversion to be the main issue causing an obsolet error?Why are some options redundant like "-c"?Why is the option "-masm=" set twice with different values?Since there are many arm chips out using an assembler startup script based on armasm, is there a conversion tool to gnuasm for those armasm?How can I compile the armasm based file seperately and link it later?
Hello
This forum is for questions on how to use the Community. Please could you take a look at Forums and let me know which forum I can move this question to?
Oli
Arm Community Manager
when I look up this topic, Accessing uv2csolution Command-Line Tool in CMSIS comes close to my questions.Therefore Support Forums and Keil Forum would be suitedThank's a lot >.<
Maik
No problem, the post has been moved :)
