Site
Search
User
Site
Search
User
Forums
Keil forum
The linking issue of the TrustZone project across multiple projects.
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
1 reply
Subscribers
24 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Ava Bennett
over 1 year ago
I have two TrustZone projects (SE_Part1 and SE_Part2), both compiling fine individually.
However, when combined into a multi-project workspace (SE_ALL), compiling SE_Part1 in Keil triggers an error:
se_part1.axf: Error: L6449E: I/O error writing
'.\Obj\SE_Part1_CMSE_Lib.o'
(file not found).
Per the Using TrustZone on Armv8-M guide, CMSE_Lib.o should be generated as <projectname>_CMSE_Lib.o in the Objects directory.
Keil auto-generates SE_Part1_CMSE_Lib.o but fails to locate the Obj folder, even though it exists under SE_Part1.
Manually creating an Obj folder in the SE_ALL directory resolved the error.
This workaround pollutes the project structure, forcing me to create redundant folders like xxx_prj\Build\Obj and explain their purpose to collaborators.
This is likely a bug: SE_Part1_CMSE_Lib.o should always generate in SE_Part1\Obj, regardless of workspace context.
Has anyone encountered the same problem? If so, how can this problem be solved?
0
Ava Bennett
over 1 year ago
IDE-Version:
μVision V5.34.0.0
Tool Version Numbers:
Toolchain: MDK-ARM Plus Version: 5.34.0.0
Cancel
Vote up
0
Vote down
Cancel
