Example TrustZone project for Cortex-m85
Is there any example TrustZone application for Cortex-M85? I use MPS3 FPGA image (AN555, SSE-310) and KEIL IDE. The IDE does not provide any example TrustZone Project. I am having difficulty creating from scratch (Configuring NS and S).  If anyone has an example project for the Image please share.
Thank you for your time.
  • You are right that there are currently no TrustZone examples in the ARM::V2M_MPS3_SSE_310_BSP pack for the Cortex-M85. There are a few TrustZone examples for the Cortex-M55 in the ARM::V2M_MPS3_SSE_300_BSP pack. You could try to convert one of those examples to a Cortex-M85.
  • Hi there, I have moved your question to the Architectures and Processors forum. Many thanks.
    Edit: moved back to Keil forum based on Hans recommendation. Thanks.
  • I am trying to create a TrustZone project for the Cortex-m85 (AN555 FPGA image for MPS3 board).
    The default linker script loads the non-secure project on 0x1020000 memory(in SRAM). So am using the MPC API functions to configure the memory region to non-secure(mpc_sie_get_region_config).
    I am using 0x57000000 as the controller address found in the AN555 document as shown below in the screenshot.
    But as soon as the memory gets configured as Non-secure it wipes out the code loaded previously on that region.
    API call to configure as non secure: enum mpc_sie_error_t mpc_config_ret = mpc_sie_config_region(&dev_test, 0x01020000, 0x011FFFFF, mpc_attr);
    Before MPC API call:
    After the MPC API call:
    Verification code to check MPC configuration: mpc_current_config_ret = mpc_sie_get_region_config(&dev_test, 0x01020000, 0x011FFFFF, &mpc_get_config_holder);
    which sets the value of mpc_get_config_holder to MPC_SIE_SEC_ATTR_NONSECURE. And return value is MPC_SIE_ERR_NONE so the configuration seems to be correct as requested.
    Can anyone please suggest why this might happen?
