Error: Flash Download failed - Could not load file 'ProjectFON\ProjectFON.axf'
Please help how to generate the .axf ....
  • 1. Confirm the Keil product and version in use
    2. What Debug Adapter is connected?
    3. What is the target selected?
  • 1. Confirm the Keil product and version in use -> mdk538a.exe
    2. What Debug Adapter is connected? ->  STM32F401RET6
    What is the target selected? -> To add code as below in main.c line 87
    To toggle start LED by adding the following application code:
    /* USER CODE BEGIN WHILE */
    while(1)
    /*start toggling LED with 100ms delay*/
    HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
    HAL_Delay(100);
    /* USER CODE END WHILE */
    Open main.c and add LED GPIO
    toggle application with HAL API in
    main.c :
    while(1)
    /* USER CODE BEGIN 3 */
    HAL_Delay(100); //in ms
    /* USER CODE END 3 */
    and
    main.c line 87
    while(1)
    HAL_Delay(100);
  • I recommend comparing your project with the CMSIS-RTOS Blinky example project and its settings, offered by the Pack Installer of Keil MDK
