Compile error when calling arm_sin_f32() function
At the end of the main function in the igpio_led_output.uvprojx project, a piece of code is added to generate a sine wave array, and two header files, math.h and arm_math.h, are added at the beginning:
#include "board.h"
#include "fsl_debug_console.h"
#include "fsl_gpio.h"
#include "stdio.h"
#include <math.h>
#include "arm_math.h"
#include "pin_mux.h"
#include "clock_config.h"
    while (1)
        delay();
                delay();
                delay();
                delay();
#if (defined(FSL_FEATURE_IGPIO_HAS_DR_TOGGLE) && (FSL_FEATURE_IGPIO_HAS_DR_TOGGLE == 1))
        GPIO_PortToggle(EXAMPLE_LED_GPIO, 1u << EXAMPLE_LED_GPIO_PIN);
#else
        if (g_pinSet)
            GPIO_PinWrite(EXAMPLE_LED_GPIO, EXAMPLE_LED_GPIO_PIN, 0U);
            g_pinSet = false;
        else
            GPIO_PinWrite(EXAMPLE_LED_GPIO, EXAMPLE_LED_GPIO_PIN, 1U);
            g_pinSet = true;
#endif /* FSL_FEATURE_IGPIO_HAS_DR_TOGGLE */
                for(i=0; i< block_size; i++){
//                xTimeWave[i] = testdatas[i];
                xTimeWave[i] = arm_sin_f32(2*PI*ff*i);
                printf("%d,%8.6f,\r\n",i,xTimeWave[i]);
//                sprintf(printstr, "%04d=%8.6f\r\n", i, xTimeWave[i]);
//                PRINTF(printstr);
Compile error message:
compiling arm_sin_f32.c...
../../../../../../CMSIS/Include/core_cm.h(81): error: #35: #error directive: "Compiler generates FPU instructions for a device without an FPU ( check __FPU_PRESENT)"
#error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
..\..\..\..\..\..\CMSIS\DSP_Lib\Source\FastMathFunctions\arm_sin_f32.c: 0 warnings, 1 error
Excuse me, where is the problem?
Thanks!
  • Hello, I have moved your question to the Keil forum.
    For the above, can you share the compiler settings, or the project itself. The error is saying that the compiler settings are for a processor with floating point unit, but the project device settings are the opposite.
    If the project is private, it may be best to raise an official support case via the support menu above.
