Site
Search
User
Site
Search
User
Forums
Keil forum
LPC845 - ARM Compiler V6 - Declaring and using constants in LP845_startup.s assembly code
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
25 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
SudeshS108
over 6 years ago
I am looking for an example with the Arm V6 compiler, for reading and writing
GPREG0 register of the PMU on the L
PC845.s?
Specifically, how do you do something like a #define in the assembly code with the ARM V6 compiler?
For the V5 compiler, I can do something like this:
DL_SIG_ADDR EQU 0x40020004 ; GPREG0 address is
0x40020004
And then use it in the assembly code like so, where I load the GPREG0 address into R1 and then I can read the contents of this register:
LDR R1, =DL_SIG_ADDR
LDR
R2
, [R
1
But for the V6 compiler, if I use the "EQU" instruction, I get a compiler error as follows:
Build started: Project: osr_boot_lpc845_brk
*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'
Build target 'osr_app_lpc845_brk release'
startup/startup_LPC845.s(94): error: unexpected token in argument list
assembling startup_LPC845.s...
"release\osr_boot_lpc845_brk.out" - 1 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:00
