Breakpoint in ISR does not allow single stepping with XDS110 debugger
I am running an application on the simplelink evaluation board MSP-EXDP432E401Y with the XDS110 debugger that is integrated into the eval board.  When I insert a breakpoint into an ISR the break happens but I am unable to do anything but hit run again.  There is no single stepping capability.  Single stepping works fine outside the ISR.  Is there a compiler setting that should be set?
  • I believe you have misunderstood my question.  When the Keil IDE is set of a breakpoint in an ISR (it really doen't matter why) the breakpoint occurs and the execution is halted with the run point cursor at the breakpoint.  However, none of the step functions (over, into, run to cursor) are enable and the keystrokes normally associated with those actions do not work.  I am asking is this a problem with the IDE, or possibly the XDS110 debugger I am using.
  • I am asking is this a problem with the IDE, or possibly the XDS110 debugger I am using.
    Again, you could narrow that down by trying a different debugger and/or trying a different IDE.
