UART_FINAL
#include "LPC17xx.h"                    // Device header
enum state_t{idle=0,AA,Cal_lnth,Evt_Data_clt,Cmd_Data_clt,Ack_Data_clt,cal_Check_sum};
enum events_t{aa=0x55,event=0x55,BB=0xbb,ack=0x33,cmd=0xcc,length};
uint16_t time_out=0;
uint8_t packet[32],Index=0,Event,ps,Start,Flag,sum=0,loop_counter,process=0,*ptr,Packet_size=0,timeout=0;
uint8_t Evt_ack_to_tx[]  = {"Event PACKET IS VALID"};
uint8_t CMD_ack_to_tx[]  = {"COMMAND PACKET IS VALID"};
uint8_t ACK_ack_to_tx[]  = {"ACKNOWLEDGE PACKET IS VALID"};
uint8_t Evt1_ack_to_tx[] = {"Event PACKET IS INVALID"};
uint8_t CMD1_ack_to_tx[] = {"COMMAND PACKET IS INVALID"};
uint8_t ACK1_ack_to_tx[] = {"ACKNOWLEDGE IS INVALID"};
/*struct State_Matrix
   enum state_t  Current_state;
   enum events_t Current_event;
   enum state_t     Next_state;
 S_Matrix[]  = { {       idle   ,        aa,  AA            },
      {         AA   ,     event,  Evt_Data_clt  },
      {         AA   ,       cmd,  Cmd_Data_clt  },
      {         AA   ,       ack,  Ack_Data_clt  },
      {Evt_Data_clt  ,    length,  cal_Check_sum },
      {Ack_Data_clt  ,    length,  cal_Check_sum },
      {Cmd_Data_clt  ,    length,  cal_Check_sum },
      {          AA  ,    timeout,     idle      },
      {Cal_lnth      ,    timeout,     idle      },
      {Evt_Data_clt  ,    timeout,     idle      },
      {Ack_Data_clt  ,    timeout,     idle      },
      {Cmd_Data_clt  ,    timeout,     idle      },
void f1(uint8_t i,uint8_t a[]);
void f2(uint8_t i,uint8_t *ptr);
void f3();
enum events_t f4();
enum events_t f5();
enum events_t f6();
struct State_function
 char name[20];
 void (*func)();
Function[]  = {      {"    idle     ",       &f1 },
      {"     AA      ",       &f2 },
      {"Cal_lnth     ",       &f3 },
      {"Evt_Data_clt ",       &f4 },
      {"Cmd_Data_clt ",       &f5 },
      {"Ack_Data_clt ",       &f6 },
 while(packet[i]!=aa)
 i++;
 ps = AA;
 LPC_TIM0->TCR = 1;
 if(packet[i] == 0x55)
 *ptr = Evt_Data_clt;
 else if(packet[i] == 0x33)
 *ptr = Ack_Data_clt;
 else if(packet[i] == 0x55)
 *ptr = Cmd_Data_clt;
 else
void  f3()
 LPC_TIM0->TCR = 1;
enum events_t f4()
 LPC_TIM0->TCR = 1;
 if(length>16)
 ps = cal_Check_sum;
enum events_t f5()
 LPC_TIM0->TCR = 1;
 if(length>14)
 ps = cal_Check_sum;
enum events_t f6()
 LPC_TIM0->TCR = 1;
 if(length>16)
 ps = cal_Check_sum;
void display(uint8_t var[])
 uint8_t i = 0;
 while(var[i++]!='\0')
  while(LPC_UART0->LSR&(1<<5))
  LPC_UART0->THR = var[i];
void Check_sum_validation()
 uint8_t Length;
    Length = sum;
  process = 1;
 loop_counter = 0;
 if(packet[1]==0x55)
  if(packet[15]==0xbb)
   while(loop_counter<14)
   sum += packet[loop_counter++];
   if(sum==packet[14])
   display(Evt_ack_to_tx);
   else
   display(Evt1_ack_to_tx);
 else if(packet[1]==0x33)
   while(loop_counter<12)
   if(sum==packet[13])
   display(ACK_ack_to_tx);
   else
   display(ACK1_ack_to_tx);
 else
   while(loop_counter<Length)
   if(sum==(packet[Length]+packet[Length-1]))
   display(CMD_ack_to_tx);
   else
   display(CMD1_ack_to_tx);
 if(Flag!=1)
 ps = idle;
 process=0;
void data_collect()
 uint8_t Length = sum;
 LPC_TIM0->TCR = 1;
 if(*ptr == 0x55)
  while(Length++<13)
   while(LPC_TIM0->IR==0)
   LPC_TIM0->IR = 1;
   if(~Flag)
       ps = idle;
       break;
    else
    Flag = 0;
    LPC_TIM0->TCR=1;
 else if(*ptr == 0x33)
  while(Length++<13)
   LPC_TIM0->IR = 1;
   if(~Flag)
   ps = idle;
   break;
   else
   Flag = 0;
   LPC_TIM0->TCR=1;
 else
  while(Length++<Packet_size)
   while(~timeout)
   if(~Flag)
     ps = idle;
     break;
   else
   Flag = 0;
   LPC_TIM0->TCR=1;
void Cmd_pck_size_clt()
  uint8_t Length = 0;
       LPC_TIM0->TCR=1;
       while(Length<2&ps!=idle)
  if(Flag)
   sum += packet[(Length++)+2];
   Flag = 0;
  if(ps!=idle)
  ps = Cmd_Data_clt;
int UART0_IRQHandler()
 LPC_TIM0->TCR = 2;
 packet[Index++] = LPC_UART0->RBR;
 Flag   = 1;
void TIMER0_IRQHandler()
 LPC_TIM0->TCR = 2;//TIMER0_IRQHandler,precounter are reset
  Index  = 0;
   ps = idle;
 LPC_TIM0->IR = 1;//TIMER0 interrupt disabled
int main()
 LPC_GPIO3->FIODIR3 = 0xff;
 LPC_GPIO3->FIOPIN3 = 0x00;
 LPC_SC->PCONP  = (1<<3|3<<1);//poweron uart0 in pconp register at bit3 and timer0
 LPC_SC->PCLKSEL0  = 0<<6;//peripheral clock select for uart0 in pclksel0 registers 6-7 bits
 LPC_UART0->LCR  = 1<<7;//divisor latch enabled in lcr register
 LPC_UART0->DLL  = 0xa1;//register contains lsb of divisor
 LPC_UART0->DLM  = 0x00;//register contains msb of divisor
 LPC_UART0->FCR  = 1;//enable fifo in fcr
 LPC_PINCON->PINSEL0 = (1<<4)|(1<<6);//ENABLED UART0 TX & RX OF GPIO
 LPC_UART0->LCR  = 0<<7;//dlab=0
 LPC_UART0->LCR  = 3|(0<<2)|(0<<3);
 LPC_UART0->IER  = 1;
 NVIC->ISER[0]  = (1<<5)|(1<<1);
 LPC_SC->PCLKSEL0  = 0<<2;//peripherical=cclk is selected for timer0
 LPC_TIM0->PR  = 0;//precount register set to zero
 LPC_TIM0->MR0  = 0xa2c3;
 LPC_TIM0->MCR  = 3;
  NVIC_SetPriority(UART0_IRQn, 0);
 while(1)
  switch(ps)
   case idle:
    if(packet[0]==0xaa)
    ps = AA;
    else
    Index  = 0;
    break;
   case  AA:
    LPC_TIM0->TCR = 1;
    if(packet[1]==0x55)
     ps = Evt_Data_clt;
     ps = Ack_Data_clt;
    else if(packet[1]==0xcc)
     ps = Cal_lnth;
    else
    break;
   case Cal_lnth:
    Cmd_pck_size_clt();
    break;
   case Evt_Data_clt:
    data_collect();
    break;
   case Ack_Data_clt:
    data_collect();
    break;
   case Cmd_Data_clt:
    data_collect();
    break;
   case cal_Check_sum:
    Check_sum_validation();
    break;
